Unknown Artist Folder with Naim Audio n-Stream
  • Liang
    • Jan 2014
    • 8
    Bought dBpoweramp in Jan. i have ripped more than 1000 CDs. All is well except that for some reason some tracks of an album is moved to a folder call 'unknown artist' in Naim n-Stream. This is when I select "Artist/Album" in n-Stream. I also notice this happen to tracks that have double track index, Track 1 01 title.
    I am using a WD My Book Duo as a NAS. I have tried just about everything and it is still the same.
    1) restarted WD NAS
    2) uninstall and reinstalled Naim n-Stream
    3) cleared UPnP Cache
    4) Re ripped
    Where is the problem, I doubt it is the ripper. Any advice? Thanks.
    Regards,
    Liang
    • 43926
    Re: Unknown Artist Folder with Naim Audio n-Stream
    What format did you rip to?
    • Liang
      • Jan 2014
      • 8
      FLAC Lossless Uncompressed
        • 43926
        It is likely a bug in the upnp server on the WD NAS, you can install something like mp3tag to double check the tags (independently) from dBpoweramp.
        • Liang
          • Jan 2014
          • 8
          Thanks for your quick response. Please recommend a NAS, Synology? My Naim dealer pointed to the NAS as well. Listening to music has never been so convenient and frustrating at the same time
            • 43926
            QNAPs give you more choice of upnp server software, our own Asset upnp is releasing soon on the qnap.
            • Liang
              • Jan 2014
              • 8
              Thanks Spoon.
