Asset UPnP for QNAP
This topic is closed.
    • 43923
    #31
    Re: Asset UPnP for QNAP
    Does Asset appear in your control point or player?
    • baardog
      • Mar 2012
      • 10
      #32
      No, it does not.
      b
        • 43923
        #33
        You have tried a full restart of the NAS?
        • baardog
          • Mar 2012
          • 10
          #34
          Yes, I did do that.
          It also shows up in the Resource Monitor.
          b
          • Declaration
            • Jan 2014
            • 23
            #35
            Originally posted by baardog
            Yes, I did do that.
            b
            Same problem here
              • 43923
              #36
              Declaration which model NAS do you have?
              • Declaration
                • Jan 2014
                • 23
                #37
                Qnap ts 212
                  • 43923
                  #38
                  Your problem is identical? in that clicking the Launch shows no page? and Asset does not show up in your control point?
                  Declaration or Baardog, are any of your familiar logging into your QNAP through SSH?
                  • Declaration
                    • Jan 2014
                    • 23
                    #39
                    I dont have any experience using ssh
                    • baardog
                      • Mar 2012
                      • 10
                      #40
                      I use SSH, to log into my router via PuTTY.
                      So I have used it before, but am still a novice.
                      I am able to go here:
                      b
                        • 43923
                        #41
                        please paste the output of:
                        ps
                        and:
                        netstat -ln
                        • baardog
                          • Mar 2012
                          • 10
                          #42
                          ps
                          and:
                          netstat -ln
                          Code:
                          [~] * netstat -ln
                          Active Internet connections (only servers)
                          Proto Recv-Q Send-Q Local Address           Foreign Address         State
                          tcp        0      0 127.0.0.1:58080         0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:49152           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:49153           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:49154           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:9251            0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:34757           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:873             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:60045           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
                          tcp        0      0 127.0.0.1:7505          0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:60629           0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:889             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:1723            0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN
                          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
                          tcp        0      0 127.0.0.1:22335         0.0.0.0:*               LISTEN
                          netstat: no support for `AF INET6 (tcp)' on this system.
                          udp        0      0 0.0.0.0:2049            0.0.0.0:*
                          udp        0      0 0.0.0.0:51714           0.0.0.0:*
                          udp        0      0 0.0.0.0:7706            0.0.0.0:*
                          udp    16128      0 0.0.0.0:68              0.0.0.0:*
                          udp        0      0 0.0.0.0:111             0.0.0.0:*
                          udp        0      0 0.0.0.0:36977           0.0.0.0:*
                          udp        0      0 0.0.0.0:631             0.0.0.0:*
                          udp        0      0 192.168.1.255:137       0.0.0.0:*
                          udp        0      0 192.168.1.11:137        0.0.0.0:*
                          udp        0      0 0.0.0.0:137             0.0.0.0:*
                          udp        0      0 192.168.1.255:138       0.0.0.0:*
                          udp        0      0 192.168.1.11:138        0.0.0.0:*
                          udp        0      0 0.0.0.0:138             0.0.0.0:*
                          udp        0      0 0.0.0.0:1194            0.0.0.0:*
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*
                          udp        0      0 0.0.0.0:55040           0.0.0.0:*
                          udp        0      0 127.0.0.1:44317         0.0.0.0:*
                          udp        0      0 0.0.0.0:55639           0.0.0.0:*
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*
                          udp        0      0 127.0.0.1:48494         0.0.0.0:*
                          udp        0      0 0.0.0.0:888             0.0.0.0:*
                          udp        0      0 255.255.255.255:8097    0.0.0.0:*
                          udp   215040      0 255.255.255.255:8097    0.0.0.0:*
                          udp        0      0 0.0.0.0:985             0.0.0.0:*
                          udp        0      0 0.0.0.0:995             0.0.0.0:*
                          udp        0      0 127.0.0.1:47589         0.0.0.0:*
                          udp        0      0 0.0.0.0:32761           0.0.0.0:*
                          netstat: no support for `AF INET6 (udp)' on this system.
                          netstat: no support for `AF INET6 (raw)' on this system.
                          Active UNIX domain sockets (only servers)
                          Proto RefCnt Flags       Type       State         I-Node Path
                          unix  2      [ ACC ]     STREAM     LISTENING     13458  @ISCSIADM_ABSTRACT_NAMESPACE
                          unix  2      [ ACC ]     STREAM     LISTENING     11545  /var/run/acpid.socket
                          unix  2      [ ACC ]     STREAM     LISTENING     73291  /var/run/cups/cups.sock
                          unix  2      [ ACC ]     STREAM     LISTENING     3969   @QNAP_NOTIFY_NAMESPACE
                          unix  2      [ ACC ]     STREAM     LISTENING     8967   //var/run/dbus/system_bus_socket
                          unix  2      [ ACC ]     STREAM     LISTENING     11128  /var/run/avahi-daemon/socket
                          unix  2      [ ACC ]     STREAM     LISTENING     52585  /var/run/rpcbind.sock
                          [~] * ps
                            PID  Uid     VmSize Stat Command
                              1 admin       564 S   init
                              2 admin           SW  [kthreadd]
                              3 admin           SW  [ksoftirqd/0]
                              6 admin           SW  [migration/0]
                              7 admin           SW  [migration/1]
                              9 admin           SW  [ksoftirqd/1]
                             11 admin           SW  [migration/2]
                             13 admin           SW  [ksoftirqd/2]
                             14 admin           SW  [migration/3]
                             16 admin           SW  [ksoftirqd/3]
                             17 admin           SW< [khelper]
                             18 admin           SW  [kdevtmpfs]
                            263 admin           SW  [sync_supers]
                            265 admin           SW  [bdi-default]
                            266 admin           SW< [kintegrityd]
                            267 admin           SW< [kblockd]
                            388 admin           SW< [tifm]
                            394 admin           SW< [ata_sff]
                            401 admin           SW  [khubd]
                            403 admin           SW  [kethubd]
                            409 admin           SW< [md]
                            421 admin           SW< [cfg80211]
                            520 admin           SW< [rpciod]
                            546 admin           SW  [kswapd0]
                            547 admin           SWN [ksmd]
                            548 admin           SW  [fsnotify_mark]
                            549 admin           SW< [nfsiod]
                            550 admin           SW< [cifsiod]
                            553 admin           SW< [crypto]
                            576 admin           SW< [kthrotld]
                            716 admin           SW< [kmpath_rdacd]
                            740 admin           SW  [scsi_eh_0]
                            743 admin           SW  [scsi_eh_1]
                            746 admin           SW  [scsi_eh_2]
                            749 admin           SW  [scsi_eh_3]
                            752 admin           SW  [scsi_eh_4]
                            755 admin           SW  [scsi_eh_5]
                            770 admin           SW  [scsi_eh_6]
                            773 admin           SW  [scsi_eh_7]
                            784 admin           SW  [scsi_eh_8]
                            787 admin           SW  [scsi_eh_9]
                            798 admin           SW  [scsi_eh_10]
                            801 admin           SW  [scsi_eh_11]
                            804 admin           SW  [kworker/u:12]
                            812 admin           SW  [scsi_eh_12]
                            815 admin           SW  [scsi_eh_13]
                            844 admin           SW< [kmpathd]
                            845 admin           SW< [kmpath_handlerd]
                            875 admin           SW< [deferwq]
                            878 admin           SW< [ttm_swap]
                            995 admin           SW  [flush-1:0]
                           1216 admin           SW  [scsi_eh_14]
                           1217 admin           SW  [usb-storage]
                           1704 admin           SW  [md9_raid1]
                           1719 admin      1116 S   /usr/sbin/rpc.mountd -F
                           1721 admin           Z < [userConfig.cgi]
                           1724 admin           Z < [authLogout.cgi]
                           1750 admin           SW  [md13_raid1]
                           1763 admin      5920 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                           1940 admin           Z < [authLogin.cgi]
                           2449 admin           SW  [kjournald]
                           2769 admin           SW  [kworker/3:4]
                           2948 admin       568 S   /sbin/daemon_mgr.nvr
                           2961 admin           SW< [cryptodev_queue]
                           3032 admin           SW  [fnotify]
                           3063 admin       324 S < qWatchdogd: keeping alive every 5 seconds...
                           3155 admin           SW< [hd-audio0]
                           3297 admin       456 S   /sbin/irqbalance
                           3506 admin           SW  [kjournald]
                           3647 admin       224 S   /sbin/modagent
                           3676 admin           SW  [md8_raid1]
                           3996 admin         4 S   /sbin/kerrd
                           4081 admin           SW  [md0_raid5]
                           4135 admin           SW  [jbd2/md0-8]
                           4136 admin           SW< [ext4-dio-unwrit]
                           4260 admin           SW  [flush-9:0]
                           4376 admin       780 S   /sbin/hotswap
                           4383 admin       688 S   /sbin/qsmartd -d
                           4425 admin           SW  [lockd]
                           4426 admin           SW< [nfsd4]
                           4427 admin           SW< [nfsd4_callbacks]
                           4428 admin           SW  [nfsd]
                           4429 admin           SW  [nfsd]
                           4430 admin           SW  [nfsd]
                           4431 admin           SW  [nfsd]
                           4432 admin           SW  [nfsd]
                           4436 admin           SW  [nfsd]
                           4437 admin           SW  [nfsd]
                           4438 admin           SW  [nfsd]
                           4445 admin           Z < [jc.cgi]
                           4614 admin      5780 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                           4687 admin           SW< [bond0]
                           4795 admin       160 S N /sbin/dhcpcd -h qnap02 -t 30 bond0
                           5432 admin       904 S   /sbin/upnpd bond0 bond0
                           5444 admin      1028 S   /sbin/upnpd bond0 bond0
                           6152 Baard Ol   6832 S   /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
                           6755 admin       948 S   /usr/sbin/rpc.statd
                           6876 admin       904 S   /usr/sbin/sshd -f /etc/ssh/sshd_config -p 22
                           6992 admin      5644 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                           6994 admin      7852 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                           6996 admin      7288 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                           7227 httpdusr   5444 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           7228 httpdusr   5588 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           7229 httpdusr   5596 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           7230 httpdusr   5424 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           7231 httpdusr   6192 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           8430 admin           SW  [kworker/1:0]
                           8788 admin           SW  [kworker/3:6]
                           9106 admin      5452 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                           9152 admin       772 R   ps
                           9163 admin      2948 S < /usr/local/sbin/_thttpd_ -p 58080 -nor -nos -u admin
                           9262 admin      5368 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                           9319 admin      1392 S   /usr/sbin/cupsd -C /etc/config/cups/cupsd.conf
                           9480 admin      2108 S   /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
                           9496 admin       980 S   /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
                           9533 guest      2272 S   proftpd: (accepting connections)
                           9632 admin       740 S   /usr/sbin/ntpdated
                           9681 admin       576 S   /usr/sbin/upsutil
                           9959 httpdusr    772 S   /sbin/lpb_scheduler -d
                           9967 admin      5516 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                           9988 admin       948 S   /sbin/genthd
                          10019 guest       552 S   /usr/sbin/dbus-daemon --system
                          10145 httpdusr   5472 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                          10235 admin           SW  [kworker/0:3]
                          10244 guest      1016 S   avahi-daemon: running [qnap02.local]
                          10367 admin       660 S   /usr/sbin/crond -l 9 -c /tmp/cron/crontabs
                          10425 admin           SW  [kworker/u:0]
                          11048 admin           SW  [kworker/1:4]
                          11110 admin      6368 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          12013 admin       844 S   /usr/bin/lunportman
                          12029 admin      1100 S   /sbin/upnpd bond0 bond0
                          12108 admin      1308 S   /sbin/bcclient
                          12160 admin      1096 S   /sbin/picd
                          12166 admin      1076 S   /sbin/gpiod
                          12170 admin       520 S N /sbin/acpid
                          12175 admin      1224 S   /sbin/hwmond
                          12207 admin       560 S N /usr/bin/rsyncd --daemon --sever-mode=1 --qnap-bwlimi
                          12406 admin       532 S   /sbin/gen_bandwidth -r -i 5
                          12485 admin           SW< [iscsi_eh]
                          12493 admin           SW  [qnap_et]
                          12500 admin       428 S   /sbin/iscsid --config=/etc/config/iscsi/sbin/iscsid.c
                          12501 admin      2152 S < /sbin/iscsid --config=/etc/config/iscsi/sbin/iscsid.c
                          12508 admin       904 S   /sbin/vdd_control -d
                          12523 admin       904 S   /sbin/lcdmond
                          13049 admin      1112 S   /usr/bin/qsyncman
                          13289 admin       696 S   /usr/sbin/openvpn --writepid /var/run/openvpn.server.
                          13373 admin      1052 S   /bin/sh /etc/init.d/klogd.sh start
                          13375 admin       868 S   qLogEngined: Write log is disabled...
                          13377 admin       744 S   /sbin/qsyslogd
                          13455 admin       816 S   /sbin/qShield
                          13463 admin       472 S   /usr/sbin/pptpd -c /etc/ppp/pptpd.conf -o /etc/ppp/op
                          13562 admin      2248 S   /usr/local/bin/porter -d 4
                          13983 admin      1188 S   /usr/local/bin/eagent -d 4
                          14005 admin       884 S   /sbin/daemon_mgr
                          14170 admin      6112 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                          14171 admin      6124 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                          14249 admin      2856 S   /sbin/upnpcd -i 300
                          14588 admin           SW  [kworker/2:1]
                          16750 admin      1440 S   /usr/local/samba/sbin/nmbd -l /var/log -D -s /etc/con
                          17849 admin       512 S   /sbin/getty 115200 tty1
                          17850 admin       512 S   /sbin/getty 115200 tty2
                          19982 admin      2060 S   sshd: admin@pts/0
                          20121 admin      1176 S   /sbin/hd_util
                          20453 admin      7444 S < /usr/local/medialibrary/bin/mytranscodesvr -d -db /sh
                          21052 admin           SW  [kworker/1:1]
                          21439 admin           SW  [kworker/1:2]
                          22168 admin           SW  [kworker/2:0]
                          23962 admin      6156 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          24772 admin       272 S   /bin/dd if=/proc/kmsg of=/mnt/HDA_ROOT/.logs/kmsg bs=
                          25964 admin           SW  [flush-9:9]
                          26137 admin           SW  [kworker/0:0]
                          26932 admin      5448 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          26950 admin      1132 S   /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
                          27154 admin      1408 S   /usr/local/samba/sbin/smbd -l /var/log -D -s /etc/con
                          27259 admin           SW  [kworker/3:0]
                          27316 admin           SW  [flush-9:13]
                          27469 admin      1236 S < /share/MD0_DATA/.qpkg/Test6/bin/AssetUPnP
                          27475 admin      1408 S < /share/MD0_DATA/.qpkg/Test6/bin/AssetUPnP
                          28227 admin           Z < [qsmart.cgi]
                          28344 admin      5996 S   /usr/local/apache/bin/apache_proxys -k start -f /etc/
                          28491 admin           SW  [kworker/0:1]
                          29094 admin           SW  [kworker/2:2]
                          29148 admin           Z < [manaRequest.cgi]
                          29238 admin       600 S   /usr/bin/portmap
                          29356 admin           Z < [devRequest.cgi]
                          29556 admin        92 S   /usr/sbin/rpc.rquotad
                          29611 admin      7616 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          29796 admin           Z < [manaRequest.cgi]
                          29899 admin           Z < [manaRequest.cgi]
                          29915 admin      1640 S   -sh
                          31336 httpdusr   5432 S   /usr/local/apache/bin/apache -k start -c PidFile /var
                          31819 admin      5952 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          31822 admin      7568 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          31824 admin      7508 S < /usr/local/apache/bin/apache_proxy -k start -f /etc/a
                          • jjo
                            • Jan 2014
                            • 18
                            #43
                            I installed Asset UPnP server on my Qnap and now my Sonos shows it as a music source. Browsing and playing music works flawlessly.
                            I do like the feature and think it's a nice way to circumvent the Sonos 64k song limitation, but I don't understand why it is visible? None of the other UPnP servers have been visible there. Is it a mistake or does Asset do something differently?
                              • 43923
                              #44
                              Not sure about the Sonos, it used to have very specific requirements (ie would only detect Windows Media Player as the upnp source), perhaps Sonos have included Asset also.
                              • baardog
                                • Mar 2012
                                • 10
                                #45
                                Did you get anything out of my output above?
