Asset UPnP for QNAP
This topic is closed.
  • michel-rose
    • Jan 2014
    • 13
    Re: Asset UPnP for QNAP
    Explorer is on your Windows computer? everything should be done on the QNAP.
    Guess he means internet explorer...
    Does not look familiair. My install was on Qnap TS-219, firmware version 4.1.0 Beta.
    Michel
    • Declaration
      • Jan 2014
      • 23
      Michel
      That is correct. I ment the internet explorer. ill checked it a view minutes ago, still the same. Do i have to activate the upnp funktion or something else in advanced on my qnap.
      THX
        • 43898
        We have an issue on this Asset QNAP release which can fill the '/' ramdisk path, we hope to release an update very soon which fixes, for now leave Asset uninstalled if you have a large collection.
          • 43898
          Updated 11th January
          We now have releases for all different versions of the qnaps, and a fix to the filling of the ramdisk problem of Test4
          • katywu
            • Nov 2011
            • 26
            Install on my QNAP 419 worked a charm but how do I set the browse tree config?
              • 43898
              #21
              The next update will allow text editing of the tree.
              • michel-rose
                • Jan 2014
                • 13
                #22
                Hi Spoon,
                Version 6 looks much improved
                Installation on TS-219, very smooth
                All albums and artists are now correctly shown
                However
                After a while (5-10 min) asset did not respond anymore.
                Unable to browse, hourglass (as it was used to be called) is on the screen for eternity but no browsing is possible.
                Tried to restart, but webpage http://QNAPTS19:45537/ does not respond.
                Tried to stop and start using the application page on qnap and sliding the switch from on=>off=>on. this worked but had no effect
                When checking the system monitor on the qnap ui, asset is on 0% of cpu usage.
                An excellent feature which i have been trying to get to work on twonky for ages, is the transcoding of flac to lpcm.
                Now my flac files are visible on by bravia kdl 46-w5500. finally i can sit on the couch and choose all music on my nas using the remote.
                Excellent work
                Hope this helps.
                KR Lammert
                • michel-rose
                  • Jan 2014
                  • 13
                  #23
                  Hi Spoon,
                  Forgot to mention in the previous post.
                  It is possible to enter the Tune in station "Netherlands" and it saved.
                  However i am not able to browse the stations in asset control
                  KR Michel
                    • 43898
                    #24
                    Noted
                    • baardog
                      • Mar 2012
                      • 10
                      #25
                      http://x.x.x.x:45537/ does not respond.
                      Running Test 6 on QNAP TS-869 Pro - Firmware 4.0.3
                      • Declaration
                        • Jan 2014
                        • 23
                        #26
                        do i need to install anything before i install the package on my Qnap TS212??
                          • 43898
                          #27
                          Nothing is needed prior to installation.
                          Baardog, does asset appear on your control point? and x.x.x.x are replaced with the actual IP address of your nas, or your browser is trying to open x.x.x.x?
                          • baardog
                            • Mar 2012
                            • 10
                            #28
                            When I hit Launch:
                            I just get this:
                            And the IP of my QNAP is 192.168.1.11
                            b
                              • 43898
                              #29
                              Perhaps you have a local firewall on your PC blocking that port?
                              • baardog
                                • Mar 2012
                                • 10
                                #30
                                Turned off Windows built-in firewall; same problem.
                                Created port-rule for AssetUPnP; same problem.
                                b
