Asset UPnP for Raspberry pi
This topic is closed.
    • 43926
    Re: Asset UPnP for Raspberry pi
    the user account which asset is running with, if you type ls -l /mnt/media/ does it list the files?
    It is possible for the pi to mount network shares, I will add a how to shortly.
    • Batleys
      • Jun 2011
      • 38
      Hi - yes I have mounted a cifs share under /mnt. I have another upnp server, miniDLNA, than can see them and index them. But Asset just seems to fail to see them - (BTW I have tried with miniDLNA both active and inactive).
      Yes I can see the files using ls -al. I have mounted using root (sudo mount -a) , and so have owner root, but have universal read access.
      I have looked in /var/log and I guess you don't write anything there?
      Simon
      • dvdr
        • Sep 2008
        • 233
        Originally posted by civiconfire
        So this currently only supports mounted usb storage? Will there be future support for NAS storage?
        You should be able to permanently mount your NAS following this guide I found and then use the last path as the media-path in Asset:
        Create a new folder named nas
        cd /home/pi
        sudo mkdir nas
        sudo chmod 777 nas
        Edit the /etc/fstab file:
        sudo nano /etc/fstab
        Add the following line:
        //192.168.1.xxx /home/pi/nas cifs guest,_netdev 0 0
        (replace 192.168.1.xxx with the actual IP-address of your nas)
        Mount the new drive:
        sudo mount /home/pi/nas
        Reboot your Raspberry PI:
        sudo reboot
        (just to make sure, maybe not necessary)
        set Assets scan-path to to /home/pi/nas (or, eventually to the subfolder you store your music in, such as /home/pi/nas/music ) and give it a go.
        Have not tested it at home, but it should work, it's a quite common way to mount a network-drive..
        You also could try to include a WOL (wake on Lan) script to start your NAS in case it's not running 24/7:
        install it on your raspberry using
        sudo aptitude install etherwake
        find the MAC address of your NAS using
        ifconfig
        edit the fstab file again (like above)
        and add the line
        sudo etherwake 00:00:00:00:00:00 (replace the numbers with the MAC-Address of your NAS)
        at the bottom of fstab and save the fstab-file
        Should do the trick: once you boot your Raspberry Pi, it shoul automatically wake your NAS as well (given, it supports WOL, of course)
        • dvdr
          • Sep 2008
          • 233
          did you by any chance have the time to look into the "softfloat"-issue? afaik, I am stuck with the softfloat-version, since I am in need for java, and the prebuilt image I am using (it's a quite common image here, after a tech-journal published a project to build a music player (HiRes music -> USB->SPDIF) based on the RPi). So a softfloat-compatible version of Asset would come quite handy to also use this project as a streaming server ...
            • 43926
            We are looking at these issues.
            • civiconfire
              • Oct 2013
              cd /home/pi
              sudo mkdir nas
              sudo chmod 777 nas
              sudo reboot
              ifconfig
              and add the line
              This worked perfectly thanks! This was about the second time I have ever worked with Linux and I found these instructions easy.
              • Pianonut
                • Apr 2009
                • 9
                #22
                This is an interesting development - I've been waiting for an excuse to but a 'Pi' - this could be it!
                Better still, and given that according to the RP.org website it is not possible to run WINE on a Pi, I add my vote to a version of Renaissance for the Raspberry Pi.
                • Batleys
                  • Jun 2011
                  • 38
                  #23
                  Hi, just enquiring to status. I still can't access my cifs mounts through Asset, even though other programmes can see them and they are clearly visible and accessible from the command line.
                  Happy to return a diagnostic version of Asset if it helps... could it be to do with character type or working directory name length??
                  Simon
                    • 43926
                    #24
                    We have a new beta soon with logging.
                    • Batleys
                      • Jun 2011
                      • 38
                      #25
                      Ok thanks for update.
                      • ChrisShorter
                        • Nov 2013
                        Thanks Spoon. This is excellent and everything worked first time for me. Far cheaper solution than buying a silent PC.
                        Chris
                        • PeteManchester
                          • Nov 2012
                          I'm not sure if it helps but Java is now available for the raspian wheezy hardfloat HardFloat Java..
                            • 43926
                            #28
                            We have had a look and it is not practical to support the softfloat version, sorry.
                            • Batleys
                              • Jun 2011
                              • 38
                              #29
                              Ok.. I have changed my cifs permission on my NAS mount to Guest, as opposed to using an authenticated user. Asset can now read and index the NAS... Strange.. But there we are.
                              Next hurdles..
                              Album art.. I have used dbpoweramp to store most album art as folder.jpg. Asset running on windows has no problems seeing and providing this. On the Pi, Asset is failing here. The only album art provided is the odd file with embedded album art that I haven't ripped with dbpoweramp.
                              The next point, not a big issue, but a bug anyway, the playlist folder size remains at 50 despite the value you try and set it on the configuration screen.
                              Simon
                              • Batleys
                                • Jun 2011
                                • 38
                                #30
                                Any update on a new beta? To resolve folder.jpg issues, provide debug, fix the auto playlist size bug, and provide the advanced features for custom menu navigation and renderer config.
                                Simon
                                It just occurred to me, does Asset use any particular libraries to read the JPEG files? If so I can check to see if they installed on my Pi..
