Problems: Adding Custom ID Tags to Asset
  • alexfra
    • Oct 2013
    In a previous Thread "Spoon" wrote:
    [COLOR="*808080"] Asset has the ability to display custom ID Tags (non-standard), with a little configuring.
    For example your FLAC library contains a unique tag of 'MOOD', you can add this to asset by:
    Start >> Run >> Regedit:
    Browse to:
    HKEY_LOCAL_MACHINE\SOFTWARE\Illustrate\dBpoweramp
    Can copy the value in 'DefaultUserPath' to Start >> Run (to open that path in Windows File Explorer).
    Open MediaDatabaseFieldsv4.txt and at the end add:
    mood,0,NVARCHAR(150)
    Where the ',0,' tells asset not to expect multi items in the field, for example artist has ,3, to allow 3 artists.
    Next in Asset Configuration >> Advances Settings add 'Mood' to the browse tree and then rebuild the database (refresh all).
    [/COLOR]
    This method doesn´t work for me.
    I am running Asset on a Win8.1 System.
    I want a Custom Tag called "Library" to tag my Files as "FLAC_HighRes", FLAC_16_44" or as "MP3.
    I´ve editet MediaDatabaseFieldsv4.txt in
    C:\Users\xyz\AppData\Roaming\dBpoweramp\uMediaLibr ary
    and
    C:\Windows\SysWOW64\config\systemprofile\AppData\R oaming\dBpoweramp\uMediaLibrary
    an added the row
    library,0,NVARCHAR(12)
    but I can´t add a Container "Library" in the Advanced Settings.
    Any Ideas?
    Greetings Alex
    • 4015
    Re: Problems: Adding Custom ID Tags to Asset
    Check this thread:
    I have my music stored in 3 libraries, one with Music in FLAC's, one with classical music and one with music in ALAC. As UPnP server I have Asset and eLyric MM. To stream the music I use a Linn DS and to operate it Kinsky or Chorus. Is there a way to make Asset show the 3 individual libraries? In both remotes (Kinsky
    • alexfra
      • Oct 2013
      Hm, that doesn't helped me.
      I tried "library,0,INTEGER", but still can't create my Container "Library" in the Browse-Tree.
        • 4015
        Click Add New Container and type Library in the Selected dropdown box.
        • alexfra
          • Oct 2013
          Ah, thats it.
          I thought the entry "Library" should be in the Dropdown List...
          Thanks a lot, now it works as it should!
