Powerfile C200 Desperately Need Help
  • MMaritz
    • Aug 2013
    • 9
    Re: Powerfile C200 Desperately Need Help
    No, it does not.
    It makes all the right noises (i.e. Carousel turning, disc mounting etc.) (Barring the sound of the disc actually spinning up), but if I double click on the drive in Explorer and it asks me to load a disc into the drive.
    If I select the disc in Slot 1 with PowerRipper, and tell the C200S to mount the disc, it does mount it, and it is then I can hear the disc spinning up and it is also visible in Windows Explorer.
    Regards,
    MM
    • MMaritz
      • Aug 2013
      • 9
      Is there anything else that I can try or investigate?
      Regards,
      MM
        • 43915
        I am thinking there must be some specific mounting step, our multi changer driver was written with the sony units (which oem a version of the powerfile).
        • MMaritz
          • Aug 2013
          • 9
          Yup, that is definitely what it looks like.
          I have even tried assigning the Sony driver to the unit in Windows, which it takes, but then it makes no difference to the behaviour of the unit under dBpoweramp.
          I really would like to use dBpoweramp with this unit, but it's not looking good...
          Is there anyone out there that actually has this setup working that could possibly help put me on the right path...?
          Regards,
          MM
          • Porcus
            • Feb 2007
            • 792
            Some utilities for the Sony: http://mysite.verizon.net/vze39sc9/mediadogg/id13.html
            Do you get mediachanger.exe to work with the Powerfile?
            • latino2006
              • Mar 2016
              I need the drivers or software for Powerfile C200, can you helpme.
              Where i can download driver or software.
              Mark
              • Saker98
                • Apr 2020
                Hello, I have a PowerFile R200, I only wish to use it to watch my DVD collection, this seems to be the only place that is working on a solution. I would be grateful for any help in this matter, if this is the wrong place, this information will also be appreciated.
                many thanks
                Saker98
