Copying tags
  • schmitty
    • Mar 2010
    • 47
    Copying tags
    Hello,
    I would like to see a utility codec added to DMC and the batch converter to allow copying of tags from an xml file or identically named file in a source directory.
    • 43915
    Re: Copying tags
    There are the DSP effects Write metadata file and Read metadata file.
    • schmitty
      • Mar 2010
      • 47
      Re: Copying tags
      I can not get the read metadata DSP to work.
        • 43915
        Re: Copying tags
        Try use the Write metadata file effect to write one, then you will know the format the xml should be in to be imported with read metadata file.
        • schmitty
          • Mar 2010
          • 47
          Re: Copying tags
          Yeah, I've already used the Write metadata file dsp to create the files. For some reason though, the Read metadata file doesn't seem to be working.
          The problem is, I have a library of original WAV files in a directory D:\Music\Original\WAV which I have remastered in a program call Platinum Notes, which then outputs the processed files into a temporary directory D:\Music\Remastered\PNTemp which appends _pn to the end of the filename eg. Track1_pn.wav. I have copied the xml files to the temp directory and added the _pn to the end of the filename, and edited the ConvertedFile properties in the xml file to
          Code:
          	<SourceFile>
          		<FileName>David Guetta - One More Love - 01 - David Guetta feat. Kelly Rowland - When Love Takes Over.wav</FileName>
          		<FileNameNoExt>David Guetta - One More Love - 01 - David Guetta feat. Kelly Rowland - When Love Takes Over</FileNameNoExt>
          		<FileNameExt>.wav</FileNameExt>
          		<FileNamePath>D:\Music\Original\WAV\CD\David Guetta\One More Love\</FileNamePath>
          	</SourceFile>
          	<ConvertedFile>
          		<FileName>David Guetta - One More Love - 01 - David Guetta feat. Kelly Rowland - When Love Takes Over_pn.wav</FileName>
          		<FileNameNoExt>David Guetta - One More Love - 01 - David Guetta feat. Kelly Rowland - When Love Takes Over_pn</FileNameNoExt>
          		<FileNamePath>D:\Music\Remastered\PNTemp\</FileNamePath>
          	</ConvertedFile>
            • 43915
            Re: Copying tags
            The item you have pasted in the code box, what is this? the xml containing tags?
            • schmitty
              • Mar 2010
              • 47
              Re: Copying tags
              Yes.
                • 43915
                Re: Copying tags
                There are no id tags, only filenames.
                • schmitty
                  • Mar 2010
                  • 47
                  Re: Copying tags
                  That was just the portions that I edited, not the full file.
                  • schmitty
                    • Mar 2010
                    • 47
                    Re: Copying tags
                    Any thoughts why the xml read is not working?
                      • 43915
                      Re: Copying tags
                      Sorry I have no ideas.
