Results 1 to 8 of 8
Thread: Automated Re-rip of inaccurate tracks?
  1. #1
    I see something in the secure section, but secure slows ripping down to a crawl.
    Any way to have Batch Ripper re-rip an inaccurate track n number of times before giving up?
    Arlo
  2. #2
    Join Date
    Apr 2002
    Re: Automated Re-rip of inaccurate tracks?
    Rather than re-rip an inaccurate track, you should set options to re-rip inaccurate frames, there is no need to re-rip any other area of the disc if ripped correctly.
  3. #3
    Where is that set?
  4. #4
    Join Date
    Jan 2011
    On profile page >> options >> secure settings >>
    Lots of options
  5. #5
    Gotcha... I know about these settings, they're the ones that significantly increase the time it takes to rip a CD.
    I thought this was a simple setting to apply during a batch rip.
  6. #6
    Join Date
    Apr 2002
    Batch Ripper has full access to CD Rippers options via the Profile button.
  7. #7
    Join Date
    Feb 2007
    Quote Originally Posted by Mute Rose View Post
    That's because it actually takes so much time to re-rip individual frames. Wouldn't go quicker to re-rip the entire track.
    When I did rip through my changer, I would set it to abort after only a few re-reads, and rather try my luck in another drive. It does not even have to be a "better" drive, just a different drive. And then I could leave it overnight there, rather than wearing the changer (which would be a much more expensive piece of equipment to replace).
  8. #8
    Join Date
    Sep 2006
    Quote Originally Posted by Porcus View Post
    Agreed: don't wear out the drive in your robot, AR. Configure the secure rip settings to abort after some reasonable amount of time, and set those CDs aside for ripping in another more disposable drive later.
    B
Posting Permissions
  • You may not post replies
  • You may not edit your posts
