No CD Drive Found
  • ralphisto
    • Sep 2012
    Re: No CD Drive Found
    i am still lacking of a solution. Does no one has an idea how to resolve the issue that my external drive is not properly detected by db? Windows explorer identifies the drive and can also identify the CD which is in. So, in general it's working. Just db can't identify it. Does anyone has experience with external DVD drives?
    Thx in advance
    • dbfan
      • Jan 2011
      • 937
      Your drive returns a type of 4, which means a network shard drive. You need to configure the drive to appear as a real drive not virtual one, the option to do this would be in your mac, not on windows
      • ralphisto
        • Sep 2012
        hi *********. this sounds achievable!:-) But how do i do this? Sorry, i am new to apple and hopefully you can explain it to me? thx
        • dbfan
          • Jan 2011
          • 937
          It will be an option in parallels, we cannot advise what it is called exactly as we do not run it here.
          • irumsey
            • Dec 2012
            > It did however pick-up my virtual clone drive,
            This is causing the issues, uninstall it and dbpoweramp will work (the clone program inserts its self between dbpoweramp and all CD drives, if the driver is missing features then dbpoweramp cannot work).
            Hello. I've just got round to trying this and it didn't make a difference.
            Fortunately I have solved the issue now though. I had been connecting to the PC via remote desktop which had been blocking the detection of the drives.
            When I hook up a monitor directly to the PC it is able to detect the drives even with the virtual clone drive software installed and enabled. The virtual clone drive can even be selected as a drive in the software.
            Thanks for your help.
            • Neil Donnan
              • Dec 2012
              I have the same problem with Dbpoweramp and the MacAir. I have not been able to run the debug and have no idea what the virtual drive is. Have you any advice on how to get DBpoweramp cd ripper to detect my Macbook air superdrive?
              Neil
                • 43915
                #22
                Are you using Parallels?
                • Neil Donnan
                  • Dec 2012
                  Yes I am using Parallels
                  • dbfan
                    • Jan 2011
                    • 937
                    #24
                    See:
                    By default parallels creates a virtual CD drive which dBpoweramp cannot use, dBpoweramp needs direct access to the drive. "In Parallels, go to devices, find the name of your CD Drive and select it. Parallels likes to use a virtual drive as the default CD drive. Clicking on Real Cd should also work. My external drive is
                    • Henkjan
                      • Oct 2010
                      • 24
                      #25
                      I have a similar problem: when I run CD Ripper as normal user (power user actually, Win XP SP3) the CD drive is not found, cannot do anything, it cannot read te CD, even cannot eject. but when I run the program as administrator, all is fine
                      Here is the debug text, I pressed retry a few times, and opened and closed the CD drive (button on the drive):
                      Using SCSI PassThrough [clCDDA::SetCommunication]
                      ->-> [frmMain::RefreshTrackListing]
                      Quitting Meta Thread: Quit
                      ->-> [clCDDA::ReturnDriveList]
                      Got drive C:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
                      Inquiry failed, trying larger buffer [cddaSCSIPassTru::GetDriveInfo]
                      Inquiry failed (with larger buffer) [cddaSCSIPassTru::GetDriveInfo]
                      Got drive D:\ CD ROM [cddaSCSIPassTru::FillDriveList]
                      <-<- [clCDDA::ReturnDriveList]
                      ->-> [clCDDA::ReadTOC]
                      <-<- [clCDDA::ReadTOC]
                      <-<- [frmMain::RefreshTrackListing]
                      ->-> [clCDDA::EjectCD]
                      <-<- [clCDDA::EjectCD]
                        • 43915
                        #26
                        This is correct in Windows XP, starting with Windows Vista or above you do not need to be administrator to access the CD drive directly.
                        • Henkjan
                          • Oct 2010
                          • 24
                          #27
                          Thanks for the clarification. Is there a way to grant a user sufficient rights without granting full admin rights? If so, I'll dig up my xp admin book
                          • dbfan
                            • Jan 2011
                            • 937
                            #28
                            The trouble is on co I think direct access to the cd drive is the same as direct access to a hdd, if I remember correctly.
                            • babis
                              • Mar 2013
                              I have exactly the same problem. have win 8 pro 2 x cd/dvd drives both less than 1 year old. dp writer says no drives detected.
                                • 43915
                                #30
                                CD Writer is unsupported now, we are not in a position where it can be updated to support new drives.
