Freezes while contacting AccurateRip
    • 43926
    Re: Freezes while contacting AccurateRip
    I am fairly certain it will be your security software...
    • SpaceTime
      • Aug 2012
      • 12
      I have disabled it and Windows firewall. And it worked previously with both. Should I un-install the Avast anti-virus to test?
      • dbfan
        • Jan 2011
        • 937
        As a test yes.
        • SpaceTime
          • Aug 2012
          • 12
          Didn't help.:(
          • SpaceTime
            • Aug 2012
            • 12
            Now what?
            • dbfan
              • Jan 2011
              • 937
              #21
              We are out of suggestions, sorry.
              • eaglescout1998
                • Apr 2009
                • 196
                #22
                Unless your anti-virus is a full fledged security suite with a firewall, it wouldn't block access to AccurateRip or PerfectMeta (at least, I don't see how it could).
                Do you have any other firewall installed on your system? Could your router be the culprit?
                • SpaceTime
                  • Aug 2012
                  • 12
                  #23
                  Other programs can access the data. It has been working with the router for years. No other firewall is in use.
                  • eaglescout1998
                    • Apr 2009
                    • 196
                    #24
                    Sorry you're still having problems. Does upgrading to R14.3 help?
