Different offsets on same disc
  • Porcus
    • Feb 2007
    • 792
    #46
    Re: Different offsets on same disc
    I won't speculate on the latter, but it doesn't work as of now, and it isn't supposed to. Don't even try (and again, I think you should stay away from beta software).
    Now for the former, namely verifying that the file is not corrupt, there are tools that basically invoke FLAC's verify command. Unless you are already using the foobar2000 media player, then I think the easiest tool for you to use, would be AudioTester, which you find at http://www.vuplayer.com/other.php . For that, you just drag+drop your files into a window.
    • Gbeer7
      • Mar 2011
      • 165
      #47
      Would a test conversion not do the same thing ?
        • 5743
        #48
        I believe that for your purposes converting to TEST CONVERSION will do the same thing (testing whether the files are both not corrupted and can be decoded to play properly).
        • Gbeer7
          • Mar 2011
          • 165
          #49
          Is there much of a differance between the audiotester and Test Conversion ? Must admit, getting in a real state over this stuff. Bit worried i change the offset of DBPA in error or by mistake and this will have messed all my rips up when ripping the CD's in the past. Want to re-copy them, but then i'm sure i won't be satisfied after that. Feels never ending and i'm sure people are fed up to the back teeth of me :(
            • 5743
            #50
            what in the heck did I just tell you above. Why do you ask if you don't believe the answers? TEST CONVERSION will do what you want (confirm that the FLAC files are OK). Your other question about offset, is just in how you setup dbpa with the ripper settings. It would have automatically set your offset I believe. And after that I can't see any way you accidentally changed it. None of this info is helping you I'm afraid. I continue to believe that you should put your music away for at least a year and listen to only internet radio or music services.
            • Gbeer7
              • Mar 2011
              • 165
              #51
              But if i had changed the offset it would have ruined my rips, no ? I know i'm painful, but i am concerned.
