DSP Effects R9
This topic is closed.
    • 43898
    DSP Effects R9
    Change Log:
    Added option to ReplayGain DSP effect to write iTunNORM tag from generated Replaygain value.
    EBU R128 ReplayGain calculation option added (to both Volume Normalize and ReplayGain DSP effects).
    Option on Maximum Length to Limit to a % of original length.
    ID Tag Manipulation added maximum album art (KB) size option.
    ID Tag Manipulation added remove month & day option from year.
    ID Tag Manipulation new drop track count and disc count option.
    New option to remove empty folders for Delete Source File.
    Bug Fix: EBU R128 Volume Normalize fix to gain clipping error limitation.
    Bug Fix: ID Tag Manipulation: Import Album Art now works for [artist].jpg.
    Bug Fix: Resample effect supports resampling from 176400 KHz.
    Download:
    <now released>
    • 5743
    Re: DSP Effects R9
    very nice. Will this allow the user to choose whether to use the ALBUM or TRACK RG value to transfer to iTunNORM field?
      • 43898
      Re: DSP Effects R9
      Currently it is just the track rg value, we could perhaps expand on that, but for now want to see how people get on with track gain.
      • xTobix
        • Oct 2011
        • 26
        Re: DSP Effects R9
        Spoon,
        any intentions to introduce EBUR128 tag only version as an alternative to the recently introduced applied version.
        Would be much appreciated!
        THX
          • 43898
          Re: DSP Effects R9
          Update 17th November 2012
          EBU R128 ReplayGain calculation option added.
          • xTobix
            • Oct 2011
            • 26
            Re: DSP Effects R9
            Thanks for the update...
            How far is the tag only option? Maybe something for Christmas? :-)
            Cheers,
            Tobi
            • dbfan
              • Jan 2011
              • 937
              Re: DSP Effects R9
              This update includes the tag only option
              • Manlord
                • Sep 2012
                Re: DSP Effects R9
                Have tested the new option for calculation replaygain values using ebur128 and I think it gives wrong results since albumgain is much lower than the individual tracks.
                Results
                Album: -24.03 dB
                Track 01: -11.26 dB
                Track 02: -9.04 dB
                Track 03: -12.45 dB
                Track 04: -11.17 dB
                Track 05: -12.2 dB
                Track 06: -12.74 dB
                Track 07: -11.72 dB
                Track 08: -13.15 dB
                Track 09: -12.18 dB
                Track 10: -11.53 dB
                Track 11: -12.86 dB
                Track 12: -12.01 dB
                • xTobix
                  • Oct 2011
                  • 26
                  Re: DSP Effects R9
                  Thanks *********, I will give it a try very soon!
                    • 43898
                    Re: DSP Effects R9
                    Update 20th November
                    Bug fix: EBU R128 album gain correctly calculated
                    • JayNYC
                      • Feb 2008
                      • 53
                      Re: DSP Effects R9
                      with an existing music collection, what is the best way to just write tags for iTunesNorm & ReplayGain (via calc EBUR128) without re-encoding the files? I normally use the ReplayGain Utility Codec to just write the RG tags.
                        • 43898
                        Re: DSP Effects R9
                        It is not possible at the moment until that utility codec is updated also, it will happen when these changes are found to be issue free.
                        • xTobix
                          • Oct 2011
                          • 26
                          Re: DSP Effects R9
                          Spoon,
                          Just to clarify. If I update to the latest DSP R9 version and take an existing set of FLAC files (Album X) will I be able to replace the current track replay gain tag values as well as the album gain tag with the one calculated by ebur128 using "Batch converter" or "Music converter"
                          or
                          do I have to rerip the entire CD to do this?
                          Thanks!
                            • 43898
                            Re: DSP Effects R9
                            If your tracks are lossless, you can convert FLAC >> FLAC with the effect.
                            • JayNYC
                              • Feb 2008
                              • 53
                              Re: DSP Effects R9
                              feature request: add iTunes norm tagging to the utility codec
