WMA -> MP3 crash..HELP!!!
  • Gio
    • May 2002
    Hi All,
    I`m new here so maybe you`ve already heard about this issue....
    Whenever I select a WMA file to be converted into MP3 Lame, I get an Illegal Operation Error and the application crashed and shuts down. The details of the error are...
    MUSICCONVERTER caused an invalid page fault in
    module MUSICCONVERTER.EXE at 017f:004033e9.
    Registers:
    EAX=01386d4c CS=017f EIP=004033e9 EFLGS=00010202
    EBX=007935c0 SS=0187 ESP=01386d38 EBP=007934d0
    ECX=01386d54 DS=0187 ESI=00000000 FS=7257
    EDX=00000000 ES=0187 EDI=01386fcd GS=0000
    Bytes at CS:EIP:
    66 39 72 02 75 0b b8 01 00 00 00 89 44 24 20 eb
    Stack dump:
    007935f0 00000000 00325419 00793630 00000100 007927c0 00000000 00688018 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    Please consider that I have installed the right CODEC for WMA and the one for MP3 Pro (same error if I select MP3 Pro) and I made no changes to the bitrate.
    I also installed the patch dmc_lame_enc370 with no changes.
    Any idea?
    Thanks a million for your help.
    Ciao.
    Gio
    • 43902
    Try converting it to wave, that will tell me if it is WMA crashing or Mp3. Also hold the mouse over a WMA file to get the popup info - make sure the files are not protected.
      I have a problem too. WMA converter just crashes, no matter what I try to do with it.
      For example:
      Application exception occurred:
      App: unknown (PID=0xFFF07E25)
      When: 5/14/2002 @ 14:49:38.680
      Exception number: C000001D (illegal instruction)
      Exception Flags = 0x00000000 (continuable)
      Notes Build: Release 4.51|April 3, 1997
      State Dump for Thread ID 0xF59BF861
      EAX: 00000040 EBX: 00000040 ECX: 00000000 EDX: 02AFF800 ESI: 02B1D000 EDI: 02B1D000
      EIP: 53633E40 ESP: 01C6F8DC EBP: 02AFF800 IOPL: 0 nv up ei pl nz na pe nc
      CS: 016F SS: 0177 DS: 0177 ES: 0177 FS: 299F GS: 0000 EFL: 00210202
      ---------- Code Disassembly ----------
      function: <nosymbols>+0000
      53633e1a 4b dec ebx
      53633e1b 0f8fbffeffff jnle 53633ce0
      53633e21 e9f7050000 jmp 5363441d
      53633e26 c1e804 shr eax,0x4
      53633e29 8bd8 mov ebx,eax
      53633e2b 8b3424 mov esi,[esp] ss:01c6f8dc=02b1d000
      53633e2e 8b7c241c mov edi,[esp+0x1c] ss:0260e4db=????????
      53633e32 8d5500 lea edx,[ebp] ss:0349e3fe=????????
      53633e35 8da42400000000 lea esp,[esp] ss:01c6f8dc=02b1d000
      53633e3c 8d642400 lea esp,[esp] ss:0260e4db=????????
      FAULT ->53633e40 0f12 ???
      53633e42 06 push es
      53633e43 0f16 ???
      53633e45 46 inc esi
      53633e46 100f adc [edi],cl ds:02b1d000=00
      53633e48 124e08 adc cl,[esi+0x8] ds:034bbbfe=??
      53633e4b 0f16 ???
      53633e4d 4e dec esi
      53633e4e 180f sbb [edi],cl ds:02b1d000=00
      53633e50 28d0 sub al,dl
      53633e52 0f5c ???
      53633e54 c10f57 ror dword ptr [edi],0x57 ds:02b1d000=00000000
        • 43902
        Is this encoding to a wma file?
          Yes, this is encoding from mp3 to WMA. I also tried decoding mp3 to WAV first, and then from WAV to WMA... Same thing happens again.
          I'm running Win-95 on this computer. (Of course, I installed all required system updates first.) On my other (NT 4.0) computer everything works great!
            • 43902
            I am 90% certain it works fine in Windows 95 - all I can think is that install of Windows 95 has something wrong with it (Windows 95 can become messed up after a period of time).
              Same problem here...
              I have windows 98 2nd Ed. installed and I installed the wma codec, but I can't convert from wma to mp3 or wav.
              The message it gives me is the following:
              Registers:
              EAX=015f6d4c CS=017f EIP=004033e9 EFLGS=00010202
              EBX=007932a0 SS=0187 ESP=015f6d38 EBP=007931a0
              ECX=015f6d54 DS=0187 ESI=00000000 FS=5107
              EDX=00000000 ES=0187 EDI=015f6fde GS=0000
              Bytes at CS:EIP:
              Stack dump:
              00793340 00000000 0000002c 00793330 00000100 00792560 00000000 00688010 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                • 43902
                For those with a problem converting FROM a wma file try this test:
                Look in C:\Windows\Media
                Pick any of the Wave files
                Convert it to WMA any bitrate
                Try converting the new WMA file back to wave, does it work?
