Results 1 to 3 of 3
Thread: ReplayGain values calculated during conversion and after it are different.
  1. #1
    Join Date
    Sep 2011
    Hello, I was converting some files from FLAC to mp3 and I wanted to have the result files to have ReplayGain tags on them; so the first thing that came through my mind was to use the ReplayGain DSP while converting to mp3. As calculating the ReplayGain tags after converted is another option too I tried it with one file to see if the calculated results were the same, but they aren't.
    I thought it may be because I was using the VBR mode, which I don't know if it is deterministic or not, so I switched over to CBR but the same thing happended.
    E.g.:
    Calculated during conversion:
    · RG value: -2.95 dB
    · RG peak: 0.960175
    Calculated after the conversion (vía RG utility codec):
    · RG value: -2.94 dB
    · RG peak: 0.956994
    Why are they different? Which one should be used/trusted?
    Join Date
    Nov 2007
    Location
    Florida, USA
    Re: ReplayGain values calculated during conversion and after it are different.
    You may be transferring the FLAC RG tags over to the mp3 files. In dbpa configuration settings, click on the music converter tab. Toward the bottom is a check box for "drop replay gain tags". This should be CHECKED. Then, in your conversion settings (from FLAC to mp3) you should have it using the Replay Gain DSP when it creates the mp3 files. This will create RG tags based on the mp3 files.
  3. #3
    Join Date
    Sep 2011
    Thank you for your answer garym, I've just verified that the check box is checked. As it was already I unchecked it and checked it again, but the result was the same. The ReplayGain DSP during conversion gave me different calculations than "converting" again using the ReplayGain utility codec.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
