is AccurateRip offline?
  • mickel
    • 11
    #91
    Re: is AccurateRip offline?
    Been working perfectly for 3 weeks now. So. A belated thanks for the fix. Highly appreciated.
    • christmas
      • Oct 2011
      from China today accuraterip is not working. actually from my landline (china unicom) is not working but from my mobile (china mobile) is working.
      any clues?
      • christmas
        • Oct 2011
        any clues?
        it looks like is working again now!
        • sanggarra
          • Apr 2022
          any clues?
          I am right now having this exact problem. Can't get to accuraterip.com nor dbpoweramp.com using WiFi, All other websites works.
          I can access accuraterip.com and dbpoweramp.com only when on my mobile data network (phone).
          This problem just started, I was able to access them and rip with accurate rip a couple weeks ago.
          Please help... I have tons CDs I need to rip.
            • 1745
            #95
            How can a website be down, if you can access those by mobile data network? Maybe your provider has a DNS problem.
            • sanggarra
              • Apr 2022
              I am using Google DNS (8.8.8.8). I also tried Clodflare DNS (1.1.1.1). Both can't get to either sites.
              Data Ei, are you on mobile data network? Just curious.
                • 1745
                #97
                No, I' not on a mobile data network. Can you access 89.238.182.185?
                  • 1745
                  #98
                  At the moment I'm in my office and have no Audio CD at hand. I try to ask a colleague for an Audio CD. May it is only the accurate rip service which is down.
                    • 1745
                    #99
                    So, I got an Audio CD from my colleague and could test it successfully with CD Ripper. CD Ripper showed the metadata as well as the presence in the accurate rip database.
                    • sanggarra
                      • Apr 2022
                      Thank you for trying it out on your end.
                      I know since both sites are accessible using my mobile data network, they are not down.
                      The question is why aren't they accessible on my home network using Google/Clodflare DNS. :(
                      And I was able to without issues until recently. There's no system or settings changed.
                      • sanggarra
                        • Apr 2022
                        We have not fixed it, the issue seems to be one of routing issues which effect some people some of the time.
                        Seems this was the same problem as some who experienced this back then as confirmed by Spoon at the time. It affects some users. I hope Spoon see this and help investigate if the same issue is happening again.
                        My Public IPv4 is: 24.6.75.132
                        My Public IPv6 is: Not Detected
                        My IP Location is: Fremont, CA US
                        ISP: Comcast Cable Communications LLC
                          • 43900
                          Open a command prompt (start key and type cmd.exe)
                          ping accuraterip.com
                          if that works (gets a reply):
                          tracert accuraterip.com
                          • sanggarra
                            • Apr 2022
                            Hi, Spoon. Thank you so much for responding to my call for help.
                            As requested, ping and tracert for both accuraterip.com and dbpoweramp.com:
                            Pinging accuraterip.com [89.238.133.247] with 32 bytes of data:
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Ping statistics for 89.238.133.247:
                            Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
                            C:\WINDOWS\system32>tracert accuraterip.com
                            Tracing route to accuraterip.com [89.238.133.247]
                            over a maximum of 30 hops:
                            1 2 ms 3 ms 2 ms 192.168.0.1
                            2 12 ms 11 ms 10 ms 96.120.88.189
                            3 11 ms 11 ms 10 ms po-301-1204-rur02.fremontcev2.ca.sfba.comcast.net [68.87.197.153]
                            4 11 ms 10 ms 10 ms po-2-rur01.fremontcev2.ca.sfba.comcast.net [162.151.86.221]
                            5 14 ms 13 ms 14 ms be-234-rar01.santaclara.ca.sfba.comcast.net [162.151.79.9]
                            6 17 ms 14 ms 12 ms be-39931-cs03.sunnyvale.ca.ibone.comcast.net [96.110.41.121]
                            7 15 ms 13 ms 13 ms be-3302-pe02.529bryant.ca.ibone.comcast.net [96.110.41.218]
                            8 17 ms 16 ms 12 ms 50.248.118.238
                            9 13 ms 15 ms 13 ms be2430.ccr22.sfo01.atlas.cogentco.com [154.54.88.185]
                            10 39 ms 39 ms 38 ms be3110.ccr32.slc01.atlas.cogentco.com [154.54.44.142]
                            11 38 ms 39 ms 38 ms be3038.ccr22.den01.atlas.cogentco.com [154.54.42.98]
                            12 55 ms 55 ms 55 ms be3036.ccr22.mci01.atlas.cogentco.com [154.54.31.90]
                            13 60 ms 70 ms 63 ms be2832.ccr42.ord01.atlas.cogentco.com [154.54.44.170]
                            14 67 ms 68 ms 67 ms be2718.ccr22.cle04.atlas.cogentco.com [154.54.7.130]
                            15 73 ms 73 ms 73 ms be2994.ccr32.yyz02.atlas.cogentco.com [154.54.31.234]
                            16 88 ms 93 ms 87 ms be3260.ccr22.ymq01.atlas.cogentco.com [154.54.42.90]
                            17 152 ms 151 ms 151 ms be3043.ccr22.lpl01.atlas.cogentco.com [154.54.44.165]
                            18 154 ms 152 ms 152 ms be2191.ccr21.man01.atlas.cogentco.com [130.117.49.50]
                            19 152 ms 151 ms 151 ms be2310.rcr61.b037783-0.man01.atlas.cogentco.com [154.54.61.190]
                            20 * * * Request timed out.
                            21 * * * Request timed out.
                            22 * * * Request timed out.
                            23 * * * Request timed out.
                            24 * * * Request timed out.
                            25 * * * Request timed out.
                            26 * * *
                            Request timed out.
                            27 * * * Request timed out.
                            28 * * * Request timed out.
                            29 * * * Request timed out.
                            30 * * * Request timed out.
                            Trace complete.
                            C:\WINDOWS\system32>ping dbpoweramp.com
                            Pinging dbpoweramp.com [89.238.182.185] with 32 bytes of data:
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Request timed out.
                            Ping statistics for 89.238.182.185:
                            C:\WINDOWS\system32>tracert www.dbpoweramp.com
                            Tracing route to www.dbpoweramp.com [89.238.182.185]
                            1 2 ms 2 ms 3 ms 192.168.0.1
                            2 10 ms 17 ms 10 ms 96.120.88.189
                            3 17 ms 11 ms 14 ms po-301-1204-rur02.fremontcev2.ca.sfba.comcast.net [68.87.197.153]
                            4 24 ms 11 ms 10 ms po-2-rur01.fremontcev2.ca.sfba.comcast.net [162.151.86.221]
                            5 12 ms 11 ms 11 ms be-234-rar01.santaclara.ca.sfba.comcast.net [162.151.79.9]
                            6 12 ms 12 ms 12 ms be-39931-cs03.sunnyvale.ca.ibone.comcast.net [96.110.41.121]
                            7 13 ms 14 ms 13 ms be-3311-pe11.529bryant.ca.ibone.comcast.net [96.110.33.90]
                            8 13 ms 12 ms 12 ms 50.208.233.210
                            9 79 ms 82 ms 79 ms nyk-bb1-link.ip.twelve99.net [62.115.118.120]
                            10 151 ms * 148 ms ldn-bb4-link.ip.twelve99.net [62.115.112.245]
                            11 150 ms 150 ms 151 ms ldn-b1-link.ip.twelve99.net [62.115.143.27]
                            12 161 ms 164 ms 168 ms m247-ic313694-ldn-b1.ip.twelve99-cust.net [213.248.104.150]
                            13 * * * Request timed out.
                            14 * * * Request timed out.
                            15 * * * Request timed out.
                            16 * * * Request timed out.
                            17 * * * Request timed out.
                            18 * * * Request timed out.
                            19 * * * Request timed out.
                            Looking forward to your response, thank you again. Much appreciated.
                              • 1745
                              From my point of view and my tracert results it is a bigger problem in the routing and the internet infrastructure so that you are not routed to the network of the UK based m247 network, where the servers are hosted.
                                • 43900
                                We have asked our datacenter to look into this.
