No detail pane data after "open with"
  • NorbertHD
    • Jun 2011
    The detail pane data in explorer for flac files is a fine feature of dbpoweramp. But when I choose "WMP" at "open with" in explorer, then the detail pane data is gone.
    "open with" adds the key "UserChoice" to "HKCU\Software\Microsoft\Windows\CurrentVersion\Ex plorer\FileExts\.flac\"
    When I delete the registry key "UserChoice" then the detail pane data is back, but the association between flac files and "WMP" is gone. So what to do?
    Regards, Norbert
    PS: Windows 7 x64
    • 43926
    Re: No detail pane data after "open with"
    re-run dbpoweramp configuration after doing open with
    • NorbertHD
      • Jun 2011
      I have executed dbpoweramp configuration and closed, but there was no change on detail pane.
      Then I have executed dbpoweramp configuration, disabled "Thumbnail and Property Handler" and closed. And again enabled "Thumbnail and Property Handler". But no change on detail pane.
      What else can I do?
        • 43926
        Try restarting the computer.
        • NorbertHD
          • Jun 2011
          Restarting the computer after executing dbpoweramp configuration doesn't solve the problem.
          Can you reproduce the problem and executing dbpoweramp configuration solves it for you? Or are you just guessing?
            • 43926
            I cannot reproduce, the odd thing is dBpoweramp Property handlers go in:
            HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion \\PropertySystem\\PropertyHandlers\\
            This is not even in the current user. Unless there is something taking higher preference to the property handler in the HKCU reg.
