Audio Conversion Engine, DSP effect not adding ID tags?
  • Changi
    • Jun 2011
    ACE didn't have its own section so I put this question here.
    I'm converting WAV files to MP3 files with ACE and this works fine but the program doesn't add ID tags during the process for some reason. Am I doing something wrong? I've wrote artist name in DSP effects by using module ID Tag Processing but when I convert audio files, MP3 files doesn't have artist name. Where might be the problem?
  • daren
    • 153
    Re: Audio Conversion Engine, DSP effect not adding ID tags?
    Have you tried switching on the "Write through ID tags" setting (see attached screenshot)?
    Best regards,
    Daren
    • Changi
      • Jun 2011
      I tried with that option checked and unchecked but the result is same. Still no metadata in MP3 files. Thanks for your help though!
      • daren
        • 153
        Well, it works for me :confused:
        Using the settings in your screenshot, the artist metadata from the source file gets mapped to a new metadata field called "Arnold the Artist". If there is no metadata in the artist field of the source file then this will result in no metadata in the destination file (nothing to map), this could be why you are not seeing any metadata in your file.
        Based on the data in the screenshot, I think you should be using the "Additions" tab to add fixed metadata to specified fields.
        Best regards,
        Daren.
        • Changi
          • Jun 2011
          Ah, that was the problem. Now it works Thank you daren!
