Multi Encoder does not work! (dbpoweramp 14)
Hi
I recently installed the dbpoweramp v14 in a W7 x64 with a i7 640 Processor 2 Core(s) ,4 Logical Processor(s) and initially the multi-encoder didn't work. Then I reinstalled it "as administrator" and it works well (using the 4 processors), but for a few days, only.
Now, for a unknown reason it stopped work again!..only one file is converted at a time. I made a clean uninstall and reinstall it a few times..used the DSP multi-cpu function..but..nothing worked.
I'm trying to convert other lossless files to flac..but I already tried to mp3 and so on..changed the output folders..the problem still remains.
need some help here please
I've been using Dbpweramp since a long time ago (around 5 years).
Thanks a lot
Re: Multi Encoder does not work! (dbpoweramp 14)
Are any error messages shown?
Nothing appears.
The program converts the files one by one...
And if you try to convert 10 files, it stops (freezes after the first track?).
No.
The program converts all the files, one by one.
Make sure you have dBpoweramp Reference (look in dBpoweramp Configuration), as this is required for Multi-CPU support.
On Multi-encoder is an option on the first options page to use multi-cpu, the DSP effects 'CPU Force' have no effect on multi-encoder.
Ok..that was the point.. I had the powerpack version -.-'
Now everything is working fine again!
THANKS a lot Spoon..5 stars to the support
Keep on Rock!
Tags for this Thread
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
