Results 1 to 6 of 6
Thread: Multi-CPU Ripping not enabled in r14 reference
  1. #1
    Join Date
    Sep 2010
    Howdy,
    I recently upgraded to registered reference r14 and I noticed that it is not taking advantage of Multi-CPUs while ripping. I have an AMD Phenom II X3 705e Processor.
    I looked through the settings, but don't see anything related to this.
    Thanks for any assistance,
    John
  2. #2
    Join Date
    Apr 2002
    Re: Multi-CPU Ripping not enabled in r14 reference
    What are you ripping to?
  3. #3
    Join Date
    Sep 2010
    To FLAC. BTW, the Multi-CPU encoding works fine with Music Converter.
    Last edited by dyneq; 09-20-2010 at 06:24 PM. Reason: Forgot to add some information.
  4. #4
    Join Date
    Apr 2002
    The CD drive is 100x slower than the FLAC encoder, hence why you will not see it using all cores (it does not need to).
  5. #5
    Join Date
    Nov 2007
    Location
    Florida, USA
    Correct (of course). This is normal behavior. This is what I see on my win 7 i5 machine. The slowest part is the reading from the disc drive, so at best it moves to the 2nd core briefly doing the encoding while reading of the next track begins. Of course when doing conversion from FLAC to mp3, it uses many cores at once.
  6. #6
    Join Date
    Sep 2010
    OK, thanks for your response.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
