Problem with AccurateRip database submission
  • japc
    • Sep 2010
    Hi.
    I'm having problems with EAC AccurateRip submission.
    It says "Submitting: 919 Discs 8281 Tracks", I press [Submit Now] and after a while it fails with "Error connecting to accuaraterip (sic), please check your settings."
    Tcpdumping the traffic I have
    POST /accu/submit.aspx HTTP/1.1^M
    User-Agent: AccurateRipPlugin^M
    Host: www.accuraterip.com^M
    Content-Type: multipart/form-data; boundary=---------------------------885ac593c6^M
    Content-Length: 74903^M
    ^M
    -----------------------------885ac593c6^M
    Content-Disposition: form-data; name="file"; filename="pluginpost.bin"^M
    Content-Type: application/octet-stream^M
    ^M
    <lots of binary data>
    and then the server returns
    HTTP/1.1 400 Bad Request
    Is there a limit to the submission size? (I don't really know how I got it this big)
    If I move the AccurateRipUpload.bin file aside and do the submission of only one CD it works justs fine.
    • 43918
    Re: Problem with AccurateRip database submission
    There are often submissions in the 300KB range, but if your upload speed is slow it might time out.
    • japc
      • Sep 2010
      No not slow, I work in a ISP and we have core speed.
      Can it be a db corruption? If so how can I further debug it?
        • 43918
        I have not seen this before, you are best deleting that submission and submitting in smaller blocks when ripping new.
        • japc
          • Sep 2010
          I guess so but for > 900 CDs that will be a pita.
          • hustlefan
            • Apr 2014
            • 9
            I ran into the same problem and solved it in the same way - submitted less data.
            But this is not really a satisfactory solution. Can't the server be changed to accept more data?
            I found Microsoft's Message Analyzer on the web and although this is my first time using it, I found that it shows an error 500 on the accuraterip server:
            If the server can't be fixed, maybe you can at least modify the error message to say that there's too much data instead of there is no connection and something is wrong with the settings.
            Also please correct the spelling in the error message - "accuaraterip" should be "accuraterip"
