Audio Conversion Engine Lite xml cue
  • Coennie
    • Aug 2010
    Hello,
    Is it possible to drop a xml file in a folder to create a job where you can specify in and output file and export profile?
    Regards,
    Coennie
    • 43902
    Re: Audio Conversion Engine Lite xml cue
    You might be better using scripting to do the conversion.
