Results 1 to 2 of 2
Thread: How Do I: Send radio streams to DS without transcoding
  1. #1
    Join Date
    Feb 2010
    I'm now using Cara 6 beta on my Sneaky DS and I'm enjoying BBC Radio 3 at 192kbps via RadioTime and the Linn Kinsky desktop. I can also stream the same stations via RadioTime and Asset, but asset transcodes the stream to WAV
    To be honest, I've not listened critically to the two routes, but it seems pointless transcoding what can now be played directly. How do I stop asset transcoding the stream, and if I do, will it work?
    I control Asset with Songbook, and don't really want to get my laptop out and use Kinsky desktop.
  2. #2
    Join Date
    Apr 2002
    Re: How Do I: Send radio streams to DS without transcoding
    It is not possible to pass out the untouched stream because the source of the stream is Asset (as far as the player is concerned, not the internet radio-station). That is because Asset allows browsing for the stations and the underlying stream path is not exposed until it is actually played.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
