Results 1 to 4 of 4
Thread: iTunes does not recognize wav tags?
  1. #1
    Join Date
    Mar 2010
    When importing ripped .wav files from dBpoweramp, none of the metadata or album art are recognized by iTunes.
    Win7
    dBpoweramp reference
    iTunes 9.0.3
    ripping .wav with default settings
    Also tried MediaMonkey with similar results
    The tag info does show up in Windows Explorer
    Have tried many different things including tag settings, file naming, etc.
    Is there some way to tweak dBpoweramp to improve this or is it just a limitation of iTunes?
  2. #2
    dBpoweramp Guru Wayne's Avatar
    Join Date
    Aug 2002
    Location
    Lowestoft, England
    Re: iTunes does not recognize wav tags?
    iTunes doesn't support tags in wav files.
  3. #3
    Join Date
    Mar 2010
    Location
    Australia
    WAV files in general don't support ID3 tags, as far as I know, it's something that dBpoweramp does. It's a good idea, I think ID3 should be made a standard for tagging across all audio file formats
  4. #4
    Join Date
    May 2010
    There are several tag types that can be embedded within WAV files. The most common is INFO LIST, supported by tools like MediaMonkey and MetadataTouch. There are few tools that support ID3 for WAV, such as MusicMatch Jukebox and mp3Tag Pro.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
