Problem ripping Flac 192
  • arsdreamer
    • Feb 2010
    I have been trying to rip my CDs in Flac 24/192 lately, using the DSP effects.
    As soon as I add Resampling, I start getting only small 300kb files that cant be played.
    Everything works fine with 44khz and 96khz as well. Only 192 seems to be a problem.
    Anyone with a suggestion?
    • 43919
    Re: Problem ripping Flac 192
    Confirmed bug.
    • arsdreamer
      • Feb 2010
      Is that dependent on the windows version used or is it a general bug? I'm using windows 7 x64.
      Is there any way to fix this issue? Do you know about an upcoming bug fix maybe?
      I appreciate your help!
        • 43919
        Fixed:
        Changes: Added Dither (Triangular and Rectangle) to Bit Depth DSP Effect ID Tag Processing 2 new Manipulations: Word / Character replacement and Rule based Tag Manipulation Run External can now run Batch files Playlist Writer - new effect added Resample updated to support 192KHz to 44.1KHz Fix for Resample going 44.1KHz to
