Results 1 to 4 of 4
Thread: dBPoweramp & Surround Sound Formats
  1. #1
    Join Date
    Sep 2006
    Location
    Cambridge, UK
    Question dBPoweramp & Surround Sound Formats
    Two questions regarding 5.1 channel surround sound
    1. 1) Does dB Poweramp Music Converter Reference’s Fraunhofer IIS mp3 codec support encoding to mp3Surround?
    2. 2) Can I use dBpoweramp to convert a Dolby digital AC-3 file to another surround sound compatible format (say mp3Surround is the answer to Q1 is “Yes”)? If so, how?
    Join Date
    Apr 2002
    Re: dBPoweramp & Surround Sound Formats
    1) No
  3. #3
    Join Date
    Sep 2006
    Location
    Cambridge, UK
    Question Re: dBPoweramp & Surround Sound Formats
    Quote Originally Posted by Salem874 View Post
    1. 1) Does dB Poweramp Music Converter Reference’s Fraunhofer IIS mp3 codec support encoding to mp3Surround?...
    1) No
    So then I take the text over on the Fraunhofer MP3 Code Central page which says
    Fraunhofer invented the mp3 format, with such impeccable credentials their latest mp3 surround codec can be trusted.
    ...is incorrect?
    I take that as implying MP3surround is supported?
  4. #4
    Join Date
    Apr 2002
    AFAIK it will encode to 5.1, but you cannot decode from it in dBpoweramp (for all purposes mp3 Surround is dead).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
