Hello all,
I'm fairly new to dbpowerAmp, but I have done extensive reading of the website and forum as well as a lot of tinkering with the program itself.
I have a question about an AccurateRip result I got. Here is the log -
Code:
dBpoweramp Release 13.3 Digital Audio Extraction Log from January 17, 2010 4:55 AM
Drive & Settings
Ripping with drive 'E: [Optiarc - BD ROM BC-5500S ]', Drive offset: 48, Overread Lead-in/out: Yes
AccurateRip: Active, Using C2: Yes, Cache: 6 KB, FUA Cache Invalidate: No
Ultra:: Vary Drive Speed: No, Min Passes: 6, Max Passes: 12, Finish After Clean Passes: 2
Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 60
Encoder: Wave -compression="PCM"
Extraction Log
Track 10: Ripped LBA 153217 to 171947 (4:09) in 4:25.
AccurateRip: Accurate (confidence 58) [Pass 1, Ultra 1 to 6, Re-Rip 64 Frames]
CRC32: 2EEBC9B6 AccurateRip CRC: FD6F0017 [DiscID: 011-001236ad-009cf38e-860a340b-10]
Insecure Audio from 00:02:44.760 to 00:02:44.773
1 Tracks Ripped Accurately
So the track "ripped accurately" according to AccurateRip and yet dbpowerAmp indicates "Insecure Audio" has been detected. Does this mean that dbpowerAmp corrected the insecure audio or that the insecure audio in the time indexes indicated still remains? If the latter, how can the track be considered "AccurateRipped"?
Another (different) question I have is about "CD Pressings". I borrowed a very scratched music CD from my local public library which is the same album I have at home with no scratches. The UPC's, dates and codes on the disc and back of the cases match and have the same tracks and track lengths. For all intents and purposes this is the same album, however the CRC's in dbpowerAmp shown don't match between the two CD's when ripped, even though the AccuraterRip confidence levels are still quite high for both (58-61) and when one ripped track in WAV format (with WAV tags disabled in dbpowerAmp) is compared to the same ripped track from the other CD using Windows File Compare (fc.exe in cmd prompt), it indicates many differences between the files. Long story short, could these discs be different pressings? Even though they look absolutely identical? How common are different pressings? Is it a matter of a different manufacturing plant pressing the CD's with very slightly different machines, etc.? Something like that?
Thanks for any help on these questions.
