dbPowerAmp Reference R13.3 - Trial Expired Early & Quick Review
  • 3dHeli
    • Feb 2009
    • 11
    I installed dbPowerAmp Reference R13.3, WMA Codec, DSP Effects (in that order) on 4th January 2010. Last night (7th Jan) I found out the trial had expired and the program described itself as unregistered.
    I was making other changes to the system, removing Norton 2009, and installing 2010 for example, and upgrading Nero from v7. It's Vista x32, with only mainstream software on it; Adobe Creative Design Premium Suite CS3, MS Office 2007. All updates and patches installed etc.
    I've always stuggled with Adobe activation (and Norton to some degree) and have been left with non-working software at the most awkward times (9pm on a Saturday Wedding, midnight on a Friday evening when Adobe UK has a Monday support closure) and found Adobe UK unavailable outside office hours and Adobe USA actively unhelpful. When Adobe software stops working with no notice (not even blance of trial period as a warning grace), and with the problems installing/upgrading Adobe products, I actively look for an alternative to avoid this pain. We have similar issues with Adobe on Macs also - still haven't managed to install CS3 on our Art Room macs, adobe helpfully suggests we reformat the Hard Drives and reinstall.
    Anyway, back to dbPowerAmp . . . I've seen a few threads for users that had difficulty upgrading dbPowerAmp and having to reinstall EVERYTHING - settings, codecs etc.
    ??? How can I get the trial to continue, with least amount of re-configuring (many of my settings are in the software) ???
    My Findings So Far:-
    1. Reference secure ripping, it does what it says on the tin. :D Having had about 2% of Windows Media Player 11 rips with errors (pops & clicks), which I only found out when later listening to, dbPowerAmp did as hoped. It found issue with those same problem discs, but managed to recover the tracks, mark them as secure, and they played without the problem. dbPowerAmp is fast, and once setup up, easy to use with the AccurateRip assurance on most of my CD's so far. :komisch9: It turned out that about 15% (4 out of 27) CD's had read errors, which dbPowerAmp was able to redo correctly - this also made me realise my WMP 11 library had more errors in it than I had thought.
    2. Setup and installation is not too easy (EAC looked much more difficult). Finding and configuring settings was a learning curve. Have now found alternative settings that for me, do a good job of recovering difficult CD's. Still working on Tag's.
    My Unresolved User Challenges (am searching forums for knowledge):-
    A. CD Ripper handles Artist Compilations nicely, Music Converter did not. I'm hoping I just used the wrong tags (album versus album artist etc) and am looking into this.
    B. Gapless - not sure if a live concert CD I'd converted to WMA Lossless is gapless, again working on testing this, maybe I need different player (e.g. Media Monkey).
    C. Can I rip two Audio CD's at once. I'm sure I'd read you can with dbPowerAmp, but now I can't find any information on it. I continue to search.
    D. Cue Sheets - I'd thought an early development of this was in R13.3, but I have not found it yet.
    E. Tagging Conventions - should I use 'The Beatles' or 'Beatles, the' etc, have done number of test rips (WmaL) and conversions (Wma128) to see/test effects & implications. Again still searching knowledge forums for answers, but haven't found anything yet.
    Overall thought - I usually find it easy to research information on the internet, but points A-E have left me with a lot of non-relevent information and no real answers - I keep looking.
  • 3dHeli
    • Feb 2009
    • 11
    Re: dbPowerAmp R13.3 - Trial Expired after 3 days ???
    I'm trying to work out best strategy to resovle issue with dbPowerAmp expiring it's trial too early.
    Would it be best to remove it properly (on a Vista machine) using the removal tool - http://forum.dbpoweramp.com/showthread.php?p=65427
    And then to re-install, or can the Early Trial Period Expire problem be fixed another way.
    Web site still talks of 21/30 days for dbPowerAmp/PerfectMeta respectively . . . not 3 days.
    Regards
    3dHeli
      • 43898
      If the trial has timed out (perhaps the date of the computer changed) then it will not be possible to activate it again.
      Your points:
      B: All CD Rippers rip in gapless
      C: Yes run two together, or try Batch Ripper if you have more than two drives
      D: In the beta section of this forum (a cue image codec)
      E: I prefer 'Beatles, The' to ensure compatibility with searching on all programs
      • 3dHeli
        • Feb 2009
        • 11
        Re: dbPowerAmp Reference R13.3 - License Question
        All I did was upgrade (unsing removal tools first) and fix a virus issue (again with a removal tool) and a system restore (to prior point) to undo an upgrade and then run the removal tool.
        Bring back security dongles I say :smile2: Adobe activation is the 2nd curse of my life . . . after Persimmon Homes and floor joist issues :vmad:
        I think the TAGing concerns can be set to my needs, having seen other threads that described what I wanted.
        Running 2 cd drives at once (using CD Ripper) looks like it will soon be here in a full release (beta for the moment).
        ONE LAST QUESTION - as one user, with desktop and travelling laptop, with only one in use at any one time (regarding dbpoweramp), do I need 1 or 2 licenses ??? Install EULA I understood as one license being fine (one user) for my circumstances ???
          • 43898
          You can specify the family pack when ordering which allows 5 PCs in a family.
          • slanderer
            • May 2010
            Re: dbPowerAmp Reference R13.3 - Trial Expired Early & Quick Review
            I was also under the impression that as a single user I could use my license on multiple machines. I am not a family, so I don't need any sort of family pack.
