Will dBpowerAMP Rip Part of a Track?
  • dypsis
    • Nov 2008
    • 57
    I would like to know whether dBpowerAMP will enable you to select a start and finish position when ripping a track from a CD.
    I find this useful when ripping a CD that has a hidden track. I am able to specify where I want the rip to start or finish, and therefore, remove the few minutes of silence.
    I have previously used Audiograbber. It has a great feature where you can play the track, and click a start or finish position. But as Audiograbber is no longer being developed, I thought I should start looking for something else that will do the job.
    • 43898
    Re: Will dBpowerAMP Rip Part of a Track?
    Yes click 'Rip as One'
    Hidden first tracks will be automatically highlighted in CD Ripper, nothing more to do.
    • dypsis
      • Nov 2008
      • 57
      Hidden tracks are usually at the end of an album.
      They are not really hidden. The second last track has a few minutes of silence.
      Will this still work?
      • EliC
        • 1175
        Use the remove silence DSP for this. You can select a min amount of silence to look for, and if over your min lvl the DSP will cut out the silence and create a new track for the hidden track.
        • dypsis
          • Nov 2008
          • 57
          Thanks for that guys. :komisch9: :smile2:
