2 quick questions - Disc Type and PreBatch Notes
  • EliC
    • 1175
    What is the purpose and function of the "Disc Type" and how is it used?
    Are notes typed into the prebatch notes fields just added to the batch report? I have never used this area.
    • 43923
    Re: 2 quick questions - Disc Type and PreBatch Notes
    Is it covered in the manual?
    Notes are carried over into the report.
    • EliC
      • 1175
      Found it. Just in case anyone else has the same question:
      Disc Type is used with the Manual Input & Review page (covered in detail in the next section Meta Options), Disc Type is used to verify that the Meta Data retrieved matches the expected Disc Type (either part of the box set, or not part of the box set). The CDs would be separated into two batches, normal CDs and box set CDs. If the meta data did not match the expected type the Manual Input & Review page would be shown if the option 'When Disc Count Does Not Match Expected' is checked in the meta data options.
      Pre-Batch Notes: stores extended information on a job, viewable from the notes section
