replacement prog for auxiliary ?
  • savagcl
    • Aug 2004
    • 439
    Would someone recommend a free replacement program for
    the dbpoweramp auxiliary program? One that can use "What
    U Hear". Preferably a free one.
    Except for Audacity that is. Audacity never shows any
    selection devices, at least that seems to be the case, if you
    are running under vista.
    Thanks a bunch,
    savagcl
    Re: replacement prog for auxiliary ?
    I think that MS removed the ability to record "What U Hear" in Vista, or at least I heard as much.
    • savagcl
      • Aug 2004
      • 439
      Not really.
      After 3 installs and trying 2 new cards, I finally got "What U
      Hear" to show up in vista sound. Of course, i pulled the
      latest drivers from creative to get "What U Hear" into the
      system.
      Still not sure if vista or creative controlls that...
      Is there something like auxiliary that you know of? I sure
      haven't found anything like it on the web....
      savagcl
