Question - CD-Writer R-13
  • savagcl
    • Aug 2004
    • 439
    Just burned my first CD and it worked great, good job.
    What is the numbers that was added to each title (and can i get rid
    of them in future writes)?
    Is the latest Lame version 3.96?
    thanks,
    savagcl
  • savagcl
    • Aug 2004
    • 439
    Re: Question - CD-Writer R-13
    Ment to post a couple examples.
    Title-12697453-44930
    TitleA-12666453-51426
    savagcl
      No, LAME 3.97 is out, get the r13.1 beta to get it.
        • 43902
        Have a look at naming which is setup for the CD, normally it is [artist] - [title] (in CD creation).
        • savagcl
          • Aug 2004
          • 439
          Spoon,
          I looked.
          Set mine to just plain "[Title]". Still got those numbers, what are
          they and how do i get rid of them?
          thanks for the reply,
          savagcl
            • 43902
            The original files added to the disc had those filenames?
            • savagcl
              • Aug 2004
              • 439
              Yes, they did (no numbers were present)
              example of file names on my HD:
              Maybeline_CB.mp3
              CQBoogie.mp3
              as they appeared on the CD:
              Maybeline_CB-########-#####.mp3
              CQBoogie-########-#####
              savagcl
              • savagcl
                • Aug 2004
                • 439
                LtData,
                I already have the dMC-R13-Ref-Registered (with Lame 3.97) and the
                CD Writer-Registered-r3 executables.
                thanks,
                savagcl
                • Wayne
                  • Aug 2002
                  • 1252
                  Looking at the tag information of those files what are their titles?
                  CD Writer will use the tag information to determine the filename to be created on the MP3 CD.
                  • savagcl
                    • Aug 2004
                    • 439
                    Looking at the Tag via dBpoweramp Edit Tag function the first line
                    reads as "dbpoweramp: 'Maybeline_CB; ID-Tag"
                    Under that are just line headings:
                    Artist
                    Title
                    Album
                    Track
                    Year
                    Genre
                    Comment (all are blank ,no data present except the headings).
                    ITunNORM 0000016B 00000167 000006CB 000006BB 000026E1 000026E1 000035D8 00003588 000026E1 000026E1
                    MP3Gain lines are populated with alpha-numeric data
                    Replaygain lines are populated with alpha-numeric data
                    thanks,
                    savagcl
                    • Wayne
                      • Aug 2002
                      • 1252
                      Which version tags do they use? dMC doesn't support ID3 v2.4.
                      • savagcl
                        • Aug 2004
                        • 439
                        Nothing i can see shows a version number.....
                        savagcl
                          What program did you use to create the files? Did you re-tag the files with a program like MediaMonkey or foobar2k?
                          • savagcl
                            • Aug 2004
                            • 439
                            The majority of the files were already MP3's.
                            I did run them (all files) through the latest version of the dB music
                            converter (DMC-R13-Ref) to apply the latest version of Lame (3.97)
                            and then ran through MP3Gain using Album analysys (and apply) and
                            ENCSpot to insure that the bitrate, lame version, quality, good frames,
                            and input freq was 44.1
                            Only then did i write them to a CD. The numbers only show on the CD
                            files.
                            Here is the file name as it appears on the harddrive and on the CD
                            followed by a full tag description.
                            File name on HD: ALittleBittyTear_BL.mp3
                            File Name on CD: ALittleBittyTear_BL-8137984-15856.mp3
                            Tag Desc:
                            Type: Windows Media File [.mp3]
                            Size: 2.86 MB (87% Compressed)
                            Length: 2 minutes 4 seconds
                            Channels: 2 (stereo)
                            Sample rate: 44.1 KHz
                            Sample size: 16 bit
                            Bit rate: 192 kbps
                            Audio quality: High (lossy)
                            Encoder: Lame 3.97
                            Encoder settings: Constand Bit Rate 192 kbps
                            Contains: Replay gain, ID Tag [ID3v2.3 (ANSI)]
                            Album gain: -7.03 dB
                            Album Peak: 1
                            iTunNORM: 000000C6 000000A5 00000... 000030A3 --- 00018563 00015E0D
                            MP3GAIN_Album_MINMAX: 036,208
                            MP3GAIN Undo: +002,+002,N
                            Track Gain: -2.65 dB
                            Track Peak: 0.999969
                            ______________________
                            dBpoweramp
                            I have no idea where the numbers come from, what they mean or how to stop them from happening......
                            Thoughts, suggestions, hints, advice, or help is appreciated,
                            savagcl
                              What do you have your naming scheme set to in the CD writer?
