DSP Effects Release 4
This topic is closed.
  • moley6knipe
    • May 2008
    • 97
    Re: DSP Effects Release 4
    Whoo who!!!! I'll try it, and let you know!!
    • moley6knipe
      • May 2008
      • 97
      Just run the updated DSP 4 ReplayGain on a batch of 1300 files (mainly Lame 3.92, some ALAC - all in my compilations directory) and it worked perfectly this time. Thanks Spoon!
      • Christian_S
        • Oct 2008
        • 21
        ReplayGain (Apply)
        Fixed (was not applying positive gain).
        Will release these effects shortly.
        Is the update incorporated in the download from today? If yes, I am not sure if I properly understand what is supposed to happen because nothing appears to happen. Neither M4B nor MP3 seem to be affected when converted to from FLAC, neither for positive nor for negative gains. For positive gains, the peak values are around 0.55 so I would expect something to happen, but also for negative gains there is no change. It also does not make a difference if I choose 'Album' or 'Track' mode, nor if I check or uncheck the calculation of missing values.
        I am using the following settings and steps:
        • In the configuration of Music Converted, dropping of replay gain ids is unchecked.
        • In a FLAC file, ReplayGain and Peak values are present for album and track.
        • When converting to M4B or MP3, the DSP effect 'ReplayGain (Apply)' is added. The DSP is set to 'Album' mode.
        • The DSP 'ReplayGain' is not added.
        Should this be correct?
          • 43898
          Using which version of dMC? R13.1 or .2?
          • Christian_S
            • Oct 2008
            • 21
            Version 13.1.
              • 43898
              #21
              And what was the track gain & album gain value for that track? (not peak level)
              • Christian_S
                • Oct 2008
                • 21
                #22
                Example with positive gain: +11.54 dB, both for album and track gain.
                Example with negative gain: -0.59 dB for album, -0.85 dB for track gain.
                  • 43898
                  #23
                  The reduction of volume has always worked, so the -.59 album gain should lower the audio volume, but not by much (if you convert then to wave and look in an audio editor). Which program created the replaygain tags?
                  • Christian_S
                    • Oct 2008
                    • 21
                    #24
                    dBpoweramp's ReplayGain DSP.
                    I did not check with a wave editor but the following two comparisons
                    1. Calculate the replaygain on the created M4B files.
                    2. Calculate the audio CRC for all files.
                    All identical for the different conversions.
                    I am wondering if I could have made a stupid mistake in my setup. Before posting the first time today I uninstalled the old DSP, rebooted and installed the new one. I did not un- and re-install the entire suite.
                    • Christian_S
                      • Oct 2008
                      • 21
                      #25
                      Oh, and I should perhaps add that the peak remains the same: for the negative gain at 1.
                      • Christian_S
                        • Oct 2008
                        • 21
                        #26
                        Ok, it must be my set-up or usage, but I don't understand where I am making the mistake. I have installed dBpoweramp including the required codecs and the dsp beta on an XP machine where nothing related to dBpoweramp has ever been installed.
                        I then tested with a file with replaygain of -10.28 dB (Rehab) which I converted from FLAC to MP3 using no DSP, RG (Apply) trac gain and RG (Apply) album gain. Then I converted all to WAV.
                        All look identical in a wave editor. When calculating the RG, all have identical gains and peaks, including the file where no DSP was applied.
                        I am at really at a loss where the problem lies.
                          • 43898
                          #27
                          Are you able to upload that FLAC file (rehab) to the internet somewhere? or even by email:
                          • Christian_S
                            • Oct 2008
                            • 21
                            #28
                            I have sent a shortened example which exhibits the same problem.
                            Thank you a lot!
                            • Bacchus
                              • Dec 2006
                              • 29
                              #29
                              Update to ReplayGain
                              Bug Fix: ReplayGain would not always write Album Gain. Also album gain recognized as 'album artist - album', for better separation of 'Greatest Hits' type albums.
                              Hey,
                              Ran into this issue and found out about this fix from another thread, but wanted to let you know that I can confirm this fix. Any small set of files I did (largest was 7 albums or so) would get both track and album gain applied fine. But when I tried to do my whole collection of close to 7000 tracks only the track gain was applied.
                              Installed this and it re-ran and it worked fine.
                              Peter S
                                • 43898
                                #30
                                Update to ReplayGain (Apply)
                                Would not function under certain circumstances. Install as the first message.
