Reference 12.4 Problem
  • chrism1966
    • May 2008
    Can someone help?
    I've just bought CD ripper 12.4 reference. Installed it OK, but when ripping cds it causes my pc to keep rebooting? I'm running XP sp2
    I've tried the uninstall reboot/ clean up programme then reinstall but still no luck??
    Help please?????????????:(
    • 43926
    Re: Reference 12.4 Problem
    Check your CPU is not overheating, a computer which suddendly reboots is either:
    Hardware fault (such as overheating, ram error)
    or driver causing crashes.
    • chrism1966
      • May 2008
      Pc only reboots when im using DB power amp cd ripper??
      Any ideas?
      • bhoar
        • Sep 2006
        • 1173
        Any ideas?
        Spoon gave you the pointer to the only two possible causes.
        Either malfunctioning hardware (or out of spec, such as temperature, due to misinstallation) or bugs in device drivers (see microsoft or your chipset maker to resolve).
        The crashes are not due to a defect in dbpoweramp.
        -brendan
          • 43926
          Or to put it a different way, on fully working XP system, I do not think I could get the computer to instantly reboot as you describe (with a normal, non device driver program), even if I tried.
