PerfectMeta Discussion
  • Porcus
    • Feb 2007
    • 792
    #31
    Re: PerfectMeta Discussion
    Originally posted by EliC
    Discogs
    Shouldn't be too hard either:
    • EliC
      • 1175
      #32
      http://www.discogs.com/help/api
      I am doing another large rip (about 600 discs) and find myself going to discogs very frequently when its unclear which meta source is correct. I understand it cannot be searched in the same way as other sources, however it could easily be searched by generated a first pass Perfectmeta Artist and Album, and then using those to search discogs, to get the track information. It won't help with artist and album, but another source for all of the track data, date, label, etc. would be very helpful. Not to mention another source for album art.
      • Porcus
        • Feb 2007
        • 792
        #33
        - People are writing scripts to integrate Discogs data to MusicBrainz. If they can get it into MusicBrainz, then ...
        - The Jaikoz tagger claims to auto-lookup Discogs. Don't know how or how well it works. However, it uses Amplifind sonic fingerprints.
        • EliC
          • 1175
          #34
          PerfectMeta should preventor seriously downgrade an artist from being listed as:
          Various Artist
          I have found this on quite a few from AMG in the latest batch. Most recent disc is:
          Altered Beats - Assassin Knowledges Of The Remanipulated
          • EliC
            • 1175
            #35
            When the number of tracks from 1 one the sources does not match the number of tracks on the disc, its results should be seriously downgraded.
            This should include any images. I just ripped Bows Blush. AMG returned the incorrect artist and album and didn't even have the correct track cound. However, despite PM showing that all of the AMG meta-data was wrong the AMG album art was used (GD3 pic was correct).
            If all other AMG meta-data is wrong, AMG specific meta-data should not be used.
            • EliC
              • 1175
              #36
              In this case PM actually used the AMG data for track *blooper*7 because GD3 and freedb had the same info, but this is not counted and MB actually had the same info, but spacing was different, so AMG ruled, incorrectly.
                • 43915
                #37
                Noted
                • EliC
                  • 1175
                  #38
                  Noted
                  thanks, I am actually finding this pretty frequently. Another example just to show its not a one time thing:
                  • EliC
                    • 1175
                    #39
                    Here is an example where AMG list the artist as "various artist" and where dbpoweramp actually chooses it as the correct option:
                    • EliC
                      • 1175
                      #40
                      An example where GD3, MB, and freedb agree, exactly, and disagree with AMG, yet AMG rules... is there something in the Perfectmeta about punctuation?
                      Discogs agrees with GD3, MB and fDB as well ( http://www.discogs.com/Steel-Pulse-R...release/554159 )
                      • PeterPanino
                        • Jan 2011
                        • 8
                        #41
                        Following EliC's suggestion, I post here my ideas about the Manual Meta Review window:
                        1. The Manual Meta Review window should be resizable: Actually it fills almost all of my 2560*1600 screen which is somewhat uncomfortable.
                        2. The Manual Meta Review window should have alternating white and light gray background rows, so it would be easier to overview and compare words on the same row.
                        • EliC
                          • 1175
                          #42
                          Opensource project with interesting implications and ideas relevant to PerfectMeta:
                          • EliC
                            • 1175
                            #43
                            There seems to be a bug related to punctuation. I have seen quite a few examples were GD3, MB, & freeDB agree, but the AMG result still is choosen. In these example the 3 that agree all end with some sort of punctuation (! ?) and AMG does not, but PerfectMeta chooses the AMG result.
                              • 43915
                              #44
                              Punctuation is removed from the results to compare.
                              • n0v!ze
                                • Jun 2007
                                PerfectMeta is a great addition to dBpoweramp Ripper. Like other users, I'd appreciate if one could use it for existing EAC rips consisting of CUE sheet and image file. The process of 1) unpacking the lossless image (APE, FLAC, WV) to WAV, 2) creating an ISO, and 3) mounting the ISO to a virtual drive could be automated, right? It doesn't have to be a perfect solution, i.e. no hidden track support or multi session with data tracks support is really needed for this purpose, I think. Not every body will have the time and will to re-rip hundreds of albums just to get proper metadata...
                                It would also be great if one could select additional tag fields beside the provided ones. These do not have to be spported by all providers but can be unique to a single metadata provider (like the musicbrainz id).
                                Any plans to support CUETools DB ?
