[Audio Info] Utility Codec R1
    • 43901
    A utility codec for dBpoweramp Music Converter (dMC) which extracts audio details and presents them either as a list, or a tab delimiter table (for pasting into a spreadsheet, such as Excel). Designed to extract details from 100's if not 1000's of files in one go, use with dBpoweramp Batch Converter to select all audio files with one click, download:
    It is possible to extract (as well as others):
    File Name
    Length
    Channels
    Sample Rate (Hz)
    Sample Size
    Bit Rate (kbps)
    Size (Bytes)
    Uncompressed Size (Bytes)
    Compression (% of Original)
    Type
    Path
    Audio Quality
    Encoder
    Sample Count
    Gapless
    Atoms
    Encoder Settings
    Wave Header
    Channel Mapping
    Riff Chunks
    Protected
    Contains
    ID Tags, such as: Artist, Album, Title, Track, Genre, Year, Comment, Compilation, Tempo, Encoded by, Album Artist, Composer, Disc, AccurateRipResult, AccurateRipDiscID, ReplayGain, MPEG Version, MPEG Technical, ISRC, Rating
