Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: Composer Max Batch Ripper Drivers
  1. #31
    Join Date
    Sep 2006
    Re: Composer Max Batch Ripper Drivers
    Quote Originally Posted by EliC View Post
    After ripping the first 4 discs it simply said finished batch rip. Never unloaded any discs to the output bin or got any new ones.
    After each individual disc rips should it be unloaded or does the batch ripper only load/unload them all at once?
    Yes, it should unload them as they finish. If more than one is queued up for unload while the robot is busy, then it will pick one of the queued ones, at random, to unload and reload a new disc and so on.
    You aren't, by any chance, running the batch configuration robot tests *while* the batch ripper is running, are you? Or using the front panel buttons?
    -brendan
  2. #32
    Join Date
    Sep 2006
    We did some back and forth in email and made sure we were on the same page with the same driver code.
    I got a report from Eli saying that it was working now.
    -brendan
  3. #33
    Join Date
    May 2004
    Thank you Brendan for all your help. Things seem to be good here. Hopefully now that BatchRipper 1.0 is final spoon can implement some of the other features/flags and the power of the composermax can really be tapped!!
  4. #34
    Join Date
    Sep 2006
    Great. If anyone else needs the driver for the composer max, please do not use the composer max driver posted on the first page of the batch ripper sticky thread but, instead, follow the instructions for the other "big" machines and contact illustrate directly - spoon will put you in contact with me:
    Mediatechnics, MF-Digital, Kintronics please Contact Illustrate: http://www.dbpoweramp.com/email.htm
    Add composer max to that list.
    -brendan
  5. #35
    dBpoweramp Guru LtData's Avatar
    Join Date
    May 2004
    Location
    USA
    Primera Composer: http://www.dbpoweramp.com/beta/dBpow...ser-Loader.exe
    Mediatechnics, MF-Digital, Kintronics, Composer MAX please Contact Illustrate: http://www.dbpoweramp.com/email.htm
    better?
  6. #36
    Join Date
    Sep 2006
    Quote Originally Posted by LtData View Post
    better?
    Perfect!
    -brendan
Posting Permissions
  • You may not post replies
  • You may not edit your posts
