<Power Pack Required of ID-Tag Editing>
  • MelM
    • Sep 2007
    • 15
    I bought the $18 + package about 6 weeks ago. I finally got it registered before the 30 days was up but the AMG access for 1 year ran out anyway and I repurchased it. Today, I tried to edit tag data in my archive and it looks like I also no longer have Power Pack either. I believe this is the first time I've tried to edit tracks via Windows Explorer since the 30 days was up.
    The "Edit ID Tags on Right Click Menu" configuration option is checked and is actuall on the menu. Checking the configuration window, it says "dBpoweramp: unregistered." I thought I'd registered. The ripper and batch converter work fine.
    BTW, I bought the package at the time of initial download.
    Windows Vista
    Re: &lt;Power Pack Required of ID-Tag Editing&gt;
    Is your account an Administrator account or a limited account?
    • MelM
      • Sep 2007
      • 15
      Thanks for the reply.
      My Vista account is an administrator account.
        Totally uninstall dMC (uninstall normally then do this: http://forum.dbpoweramp.com/showthread.php?t=13285) and then reinstall with your registered installers and the AMG access installer.
        • MelM
          • Sep 2007
          • 15
          Uninstall done and the cleanup program has been run. Where are my "registered installers and the AMG access installer"? I have an email from 9/30 which contains a "program download link" for the original order. I also have an email from 11/04 with a "program download link" for the second AMG access purchase. Are these what you are calling "installers"? If so, will the one from 9/30 do the job by itself? I don't want to use two attempts to "install" AMG access when the 1st will do fine.
            • 43915
            AMG is not used for ID Tag editing, visit here to install the registered version of dBpoweramp:
              I highly recommend keeping the installers for dMC and AMG. For the record, the dMC installer would be the "program download link", yes.
              • MelM
                • Sep 2007
                • 15
                Ok, the reinstall from Spoon's link is ok.
                Rip ok, AMG ok, convert ok, edit ok and the music plays.
                Thanks guys!
