-Request: add support for scripting, so the end user can add metadata from web resources or modify metadata
example:
Fixing Cases in titles, authors, ect...
http://www.mediamonkey.com/forum/viewtopic.php?t=4037
example:
Already done:
http://www.dbpoweramp.com/developer-scripting-dmc.htm
Will scripting be able to access the meta data in the tagging process at the time of ripping? Can web resources be added?
ID tag editing is done after ripping.
Option to do a test rip - no encoding, not even "test encoding"
Option to write cue sheet when ripping to individual tracks.
-write log with test rip/encoding
-skip tracks with > X or > X% individual bad frames in secure ripper settings
-skip track if any pass is >X times realtime
-also, is there a more gracefull way to cancel a rip or skip a track, if dBpoweramp has really slowed down on a rip canceling or skipping can take quite awhile.
- CD-Ripper: If all CPUs are currently encoding, read ahead and buffer at least one track. The way the ripper behaves on my dualcore system wastes up to 50% of the cpu time, and has to pause the rip even though the CPUs would be fast enough to keep up, if both were kept busy all the time.
- write metadata to file when ripping: I would love to have an option to save the metadata to a file (txt,csv or xml) when ripping a cd.
It should be fine to have a file generated in the cd folder like the image.jpg, with all metadata, filename, etc., as complete as possible, with a line for each track, containing all metadata on each line.
An extended option could be the possibility to configure the format on this file, but if we could have all metadata in a single line for each track, with ;-delilimted og tab-delimited text, it would help much.
smholt: while it isn't quite what your looking for, you would probably be interesting in this: http://forum.dbpoweramp.com/showthread.php?t=14846
Now that cue files are implemented, can we have the option to automatically create a cue file for a disc and write it to the album directory when ripping to SEPARATE tracks?
Cue is not currently implemented.
My bad. I had assumed it was part of rip as one. Completely my mistake.
Yes, and I know this is coming. Though I would like the option to generate a cue sheet without using a single audio file per disc
