Discussion of dMC R13
    • 43918
    Re: Discussion of dMC R13
    What settings are you encoding to? for me R13 final is writing the lame header (we now use lame.exe, so that writes the header, previously we had to write it ourselves).
    • fukurou
      • May 2008
      Now that R13 Powerpack is available, I wonder how I can update from R12 Powerpack? There is no possibility on the Registration retrival page, only an upgrade to R13 Reference is offered.
      • ffm76600
        • Apr 2007
        • 162
        The same with the 12.4 version
        Encoding : slow
        CBR Bitrate : 320 kbps
        Frequency : 44,1 khz (cd)
        Channels : 2 'stereo' (CD)
        Copyright, Original, Crc error protection & force iso compatibility are activate !
        Very strange !
          • 43918
          This would probabbly inhibit the lame header from being written (which would be correct as ISO compatibiliy would not have a lame header), as to why the R12.4 wrote a lame header with iso compatibility, looks like it is bug in r12 not r13...
          • ffm76600
            • Apr 2007
            • 162
            It's ok now for gapless but not for the joint stereo problem.
            I have : channels : 2 "stereo" CD but the final mp3 file is in joint stereo ! Why ?
              • 43918
              Joint Stereo will be of a higher quality at 320kbps than Stereo at the same bitrate.
              @fukurou: It is possible now to upgrade to Ref R13 from Power Pack (on retrieval page).
              • Porcus
                • Feb 2007
                • 792
                Oh, the final is out? Looks so in http://www.dbpoweramp.com/dmc-power-register.htm , though not http://www.dbpoweramp.com/dmc.htm ;-)
                (1) Should we install the final on top of existing, just as we did with the beta?
                (2) Changes compared to most recent beta?
                • ffm76600
                  • Apr 2007
                  • 162
                  Do you have a solution for my problem. Joint stereo is better for 0 to 224 kbps but not for 320 kbps
                  • fukurou
                    • May 2008
                    Yes, I know. But how can I upgrade from Powerpack R12 to Powerpack R13? I bought R12 1 year ago under the terms of free upgrades for life. Is this still valid?
                      • 43918
                      Not uninstall old
                      dMC Version Changes has been updated
                      I will mark it down to look at.
                      On Registration retrieval page.
                      • fukurou
                        • May 2008
                        OK, now I got it. I clicked the "Download" button behind the text "dBpoweramp Music Converter R12.4 (Registered)" and obtained Powerpack R13.
                        Somehow it was not clear to me, thanks.
                          • 43918
                          Corrected, now says R13
                          • hanschke
                            • May 2006
                            • 79
                            i have bought the final now and hope the lame.exe dont crash anymore
                              Not sure why, but in the final dMC r13, when going into the ID Tag Options, the scrollbar isn't clickable to where I can drag it to where I want. I can use the mousewheel to scroll or the arrow keys to scroll down through the options one a time.
                                • 43918
                                dBpoweramp Configuration, or CD Ripper?
