Wrong tracks retrieved for Mixed Mode CDs
  • Mikity
    • Aug 2007
    I have recently been ripping the audio tracks from a number of PlayStation and Saturn games I own (in this case, Wipeout 2097). These games are all mixed-mode CDs. However on an AMG/freedb query the CD Ripper retrieves the wrong tracks or rather, all track names are shifted by one. It looks like what is happening is that it is calling the first audio track "DATA", even though the data track isn't even shown in the interface so the naming should begin with the first audio track. I hope you can understand what I'm trying to say here. :blush: For example:
    Code:
    On the CD:
    1. DATA
    2. Kingkong
    3. Plasticity
    What dBpowerAMP says:
    1. (not displayed)
    2. DATA
    3. Kingkong
    Does this make any sense? Could someone verify this please?
    Cheers,
    Mikity
  • Mikity
    • Aug 2007
    Re: Wrong tracks retrieved for Mixed Mode CDs
    Wrong forum - sorry! Could someone move this post to a more appropriate section? Thanks.
      Moved to dMC Support
      If the meta-data retrieved is wrong, then it is wrong on FreeDB or AMG, not our end. If you have dMC r12.3, you can fix the meta-data then resubmit it to AMG and FreeDB.
      • Mikity
        • Aug 2007
        But EAC and iTunes use freedb as well (well, EAC for sure) and they both get it right, it's just dMC that shifts the names by one track.... tested with exactly the same CD.
          So, dMC doesn't display the DATA track but it still shows the first track as DATA, right? I have had similar problems with some of my mixed-mode CDs, as other CD software doesn't skip over the data track, therefore the meta-data has the first track as Data.
          • Wayne
            • Aug 2002
            • 1252
            Where exactly did the CD Ripper retrieve its meta data from?
            Is the problem with the data returned from AMG?
            BTW I didn't realise that we could now submit corrections to AMG/freedb using r12.3.
            Wayne
              Actually, that feature was added in r12.2, not r12.3, memory was a little fuzzy.
              • Mikity
                • Aug 2007
                That's exactly what's happening! I queried freedb from dMC and EAC, for the same Saturn game (data + audio) and dMC got it wrong, so I'm assuming a little fix is needed. Maybe just a check if the string "DATA" is found in a track name.
                By the way does Spoon read these forums too?
                Thanks, Mikity
                  Yes, Spoon checks the forum too.
                  The problem is, the meta-data has the first track as DATA, which dMC has hidden, so you get the first audio track marked as "DATA" and then all of you track names are off by one. I never found a fix for it when I had the problem other than renaming all of the tracks to the correct names.
