[IFCOMP] problems
  • markeh
    • Apr 2007
    • 45
    [IFCOMP] problems
    I am trying to get albums with multiple composers to use the album title as the highest level in the file structure.
    The string I am using is:
    [IFCOMP][album][][IF!COMP][IFVALUE]composer,[tag]composer[],unknown_composer[][]\[album]\[IFMULTI]disc [disc]-[]track [track]-[title]-[album artist]
    (no, this isn't finished- I will probably eliminate the second album reference.)
    When I do the test case in the dialog, it seems to work OK - maybe I'm wrong, since I don't listen to Madonna :smile2:
    But the first part of the name (after the IFCOMP) is never used, no matter whether the "compilation" switch is checked or now.
    I even tried some tests, using [IFCOMP]XXX[], and putting the same thing at the end of the track name. All ignored.
    What am I doing wrong?? Does the switch really control this? Or does the compilation tag need to be set somewhere else??
    thnx,
    • 43926
    Re: [IFCOMP] problems
    Using the multi encoder, or ripping direct from CD ripper?
    • markeh
      • Apr 2007
      • 45
      Ripping a CD. The "compilation" switch seems to be ignored.
        • 43926
        What happens if you click the default and use the default naming, does compilation work then?
        • markeh
          • Apr 2007
          • 45
          No. Using the default naming string, the compilation switch seems to make no difference.
          These are classical albums. The default string causes a new directory is set up, with the tracks listed in it. In this case, the new directory is named for Album Artist (which is conductor - filled in by the AMG database). Then individual tracks, with track names of:
          artist - album title - trk number - track name
          Interestingly, the album field is cut off. The AMG database lists the orchestra, followed by a ";" then more details. Everything following the ; is left off in the track title. However the album title is complete, with the ; and everything following.
          Whether the switch is on or off, the compilation = 1 tag is not listed in the mp3 tag section.
          • markeh
            • Apr 2007
            • 45
            I guess to be complete, I should add the following information:
            dBpoweramp Music Converter
            Release 12.1
            Registration Status
            Reference: Registered
            All Media Guide: 351 Days Access Remaining
              • 43926
              CD Ripper >> Options >> ID Tag Options
              do you have compilation checked there?
              • markeh
                • Apr 2007
                • 45
                Well, no it wasn't checked.
                (I must say that you don't give users much of a sporting chance. That option is buried quite deep, not something I would think that I need to look at)
                In any case, its checked now, and it hasn't made a difference.
                A few questions -
                - Should checking the "compilation" switch make a tag show up in the ID-Meta section? If doesn't.
                -Should checking the compilation switch make a compilation tag show up in the file properties page? Or the "Edit ID-tag page"? It doesn't.
                I'm sure this is my error, but I don't know what to do, and I would like to use the product.
