meta data problem with comment tag
  • toNka64
    • Mar 2007
    • 25
    I just ripped a CD to FLAC and what I entered into the comment field was not written to the comment field but instead was written to a <DESCRIPTION> field.
    Am I doing something wrong or is this a bug?
    Re: meta data problem with comment tag
    I believe that the official Vorbis comment standard is to use DESCRIPTION not "Comment". What program are you using to read the metadata?
      • 43926
      Description is correct for Ogg vorbis and FLAC.
        To clarify: it is correct when you are using Vorbis comments as the meta-data for these formats
        • toNka64
          • Mar 2007
          • 25
          That's what foobar2000 showed me.
          I thought foobar2000 handled FLAC tags 100%..?!?!
