Power Pack No Longer Registered
  • 1mck
    • Jul 2002
    • 25
    I've downloaded and installed the new version of dBpower Amp, and under the configuration portion it shows that my Power Pack is not registered anymore. Is there a special code that I have to input that I missed from before other than the CD Writer Code that I purchased as well?
    1mck
    Re: Power Pack No Longer Registered
    Did you purchase just the CD Writer or the "Fully Loaded" CD Writer, because only the fully loaded package included dMC itself.
    If you did purchase the fully loaded package, I'm not entirely sure how you can go about getting a registered PowerPack installed.
    • 1mck
      • Jul 2002
      • 25
      Thanks for your reply!
      I have purchased the Power Pack, and the CD Writer, which I guess included everything. The only thing I didn't get was the Portable Player Sync thingy. I'm kind of perplexed here as to what's going on.
      Do have a record of my account, and what I have purchased?
      Thanks in advance,
      1mck
        See the bottom part of this announcement: http://forum.dbpoweramp.com/announce...nouncementid=8
        • 1mck
          • Jul 2002
          • 25
          Thanks Lt. Data I've e-mailed Spoon about this :D
          1mck
