Won't convert AA to MP3
  • dhartson
    • Dec 2006
    • 13
    #31
    Re: Won't convert AA to MP3
    A brief correction to an earlier post:
    It is Microsoft's Internet Explorer 7 that is not compatible with Audible Manager v.4 (not MediaPlayer11; I updated both at the same time). With IE7 installed, when you try to download any books from your library, you will end up with an error message advising that you have to "delete your temporary internet files." If you receive this error message you will have to update to Audible Manager v.5
    As a reminder, if you find yourself in the position of having to switch back and forth between AudibleManger v.5 and v.4, DON'T FORGET to deactivate your players (both desktop and any/all portables) BEFORE you uninstall either version of AudibleManager (i.e., in BOTH directions, when you uninstall v.5 in order to transcode the AA files, and later when you uninstall v.4 so that you can install v.5 and download additional books from your library), AND don't forget (as I have done) that AudibleManager will automatically uninstall the version on your computer as part of the installation process of the version you are moving to (at least, when moving from v.4 to v.5).
    • rds5150
      • Feb 2007
      hey guys
      nice forum here
      im a newbie, to aa files, and im trying to go from aa to mp3, im using dbp 11.5(reg) have configured direct show, im running audible 4.0, and all that ! ! !
      about 4 min into a conversion, dbp just goes away, the 4 min mp3 file in the output folder works fine
      any idea's thanks rob
      • miznunkey
        • Feb 2007
        Version 12 doesn't have the DirectShow Codec. You can request version 11.5 Here: <removed, see below for instructions>
        Or you can wait... they say they will have the codec soon.
        Basically as of today (2007-02-27) DBpower AMP 12 = NO AUDIBLE :thumbdown
        -Miz
          #34
          Actually, there is a better way to get dMC r11.5. The procedure is described here: http://forum.dbpoweramp.com/showthre...ewpost&t=12280
