Results 1 to 7 of 7
Thread: volume normalization
  1. #1
    Join Date
    Apr 2002
    Location
    north palm beach, fl
    I need some help. I have a bunch of songs and some
    of them play a lot more quiet than others. Is there a
    simple way to get them all normalized to the same
    volume reference?
  2. #2
    Join Date
    Apr 2002
    Location
    Australia
    I think the best method is in the Powerpack. so when you rip from a cd you can select adaptive normalize.
    but for your existing files you could load dmc file selector and select all your files and through the converting process select "DSP effects" then "volume normalize" which will then present you with further options on volume normalizing.
    doing it this way may not acheive the desired results though. trial and error.
  3. #3
    Join Date
    Apr 2002
    Location
    I did that, but it doesn't do what I expect.
    I'd like the normalization to normalize to the
    most extreme file, either lower all the files to
    the lowest file or increase the volume of all
    of the files to the highest file. How does
    normalization work? What are the different
    types of normalization and what do they do?
  4. #4
    Join Date
    Apr 2002
    Location
    Australia
    I think Spoon can answer this better. but from memory I think it adapts to the highest volume file. but I could be wrong.
  5. #5
    Join Date
    Apr 2002
    Location
    Australia
    I found the answer in the FAQ section.
    look here:
    http://forum.dbpoweramp.com/showthre...s=&threadid=12
  6. #6
    Join Date
    Apr 2002
    You also might want to try out Replay Gain, which is a methodology for normalizing audio files. Spoon says dBpowerAMP will be supporting it in the future (hurry up Spoon! :-), but for now you can get an app called MP3Gain (search Google). It will analyze MP3 files and adjust the volume up or down to the level you want or to a standard volume that you use for everything. It can also adjust all of the tracks from a CD and raise/lower all of them by the same level, so that quieter tracks remain quieter than the others. But for random play, I have it do each track individually.
    It rewrites your MP3 files, so keep that in mind. It doesn't lose any quality, but the original volume level of the tracks will be gone of course. In MP3 files, the volume is encoded separately from the audio data, so adjusting it doesn't mess with the audio itself (except of course the volume :-).
    I've had it refuse to process some files that it says are not true MP3, usually weird files I got off Napster. It has worked fine on everything that I've ripped myself.
  7. #7
    Join Date
    Apr 2002
    Location
    Yorkshire, United Kingdom
    You can pick up Mp3Gain from http://www.geocities.com/mp3gain/ - bear in mind that it is very slow (about 2 mins per MP3), so don't go normalising your entire collection in one go.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
