MAREO: instructions for adding it to dbpamp ...
    Re: MAREO: instructions for adding it to dbpamp ...
    Well it makes sense, because an input WAV cannot have tags.
    • kwanbis
      • Mar 2006
      • 45
      It is ripping from CD to MP3. dbpamp has all the info, and needs only to pass it to the encoder, so it can use it. It doesn't makes sence.
        • 43921
        Very odd, the tags are going missing, but where?
        • kwanbis
          • Mar 2006
          • 45
          i really don't know, they are loaded on dbpamp ... cause i see them, so dbpamp should be passing them to MAREO, but it is not :|. As you may know, i use dbpamp myself, and MAREO is free/gpl, so i'm trying to make it work out of curiosity mostly. Have you tried it?
          also, why is that is not space being passed between the command line and the first parameter?
          • kwanbis
            • Mar 2006
            • 45
            no ideas?
              • 43921
              #21
              Sorry no.
              • gameplaya15143
                • Sep 2005
                • 276
                #22
                I finally have a weekend to mess with stuff...
                I will attempt to use mareo to apply replaygain (with vorbisgain) to my ogg vorbis files automatically after I rip a CD.
                In theory, mareo should be able to do this correct?
                • gameplaya15143
                  • Sep 2005
                  • 276
                  #23
                  well... i honestly don't think that mareo will work with dmc
                  how does mareo determine when something is the 'last song'?
                  the way dmc works... mareo would be called for each track seperately... and after mareo is done with one track, it has to close (lets dmc know its done running).. then dmc moves on to the next track
                  i might be wrong on that... so.. spoon, you wrote dmc, so you can explain it better than me
                  • kwanbis
                    • Mar 2006
                    • 45
                    #24
                    MAREO works with Exact Audio Copy (EAC), Plextools Professional XL, Audiograbber, foobar2000, CDex, all CD rippers, that work the same as dbpoweramp. MAREO works like any CLI encoder, but somehow, i can't make dbpoweramp pass parameters not only to MAREO, but to LAME, or whatever.
                      • 43921
                      #25
                      The CLI encoder is very shortly due for a rewrite for R12 (as soon as File Selector and CD Ripper are done), this issue will be addressed then.
