PerfectTUNES Not Seeing DSF Files
I've recently been ripping the DSD tracks from my collection of SACDs. These end up as DSF files, and generally the metadata is correctly attached, but not always the case. I've tried using PerfectTunes to fix these, but it doesn't appear to "see" this type of file. Is it me, or is this a feature of the program? Thanks in anticipation.
Re: PerfectTUNES Not Seeing DSF Files
Thanks for your feedback. DSD codec is missing from the Mac version of PerfectTUNES and will be added in the next update.
Fixed:
[url]https://forum.dbpoweramp.com/showthread.php?41506-PerfectTUNES-for-Mac-R2-3-beta[/url]
To Moderator:
Purchased PerfectTUNES in past. Downloaded DSF update from link on forum here. Somehow deleted previous registered PerfectTUNES application. Now only Beta PerfectTUNES shows. Need registered PerfectTUNES with the DSF update. Changed my email used for previous PerfectTUNES registration. Do have previous dBPoweramp registration licenses purchased for both Windows and Mac. Can't locate a PerfectTUNE registration license however.
Lost your order number? visit: [url]https://secure.dbpoweramp.com/lostorder.aspx[/url]
It is not possible to have the registered version with DSF update until the beta is released.
[QUOTE=Spoon;189853]Lost your order number? visit: [url]https://secure.dbpoweramp.com/lostorder.aspx[/url]
It is not possible to have the registered version with DSF update until the beta is released.[/QUOTE]
So the just linked DSF beta out now is only for testing purposes? Will wait for official beta release then.
I know I purchased PerfectTUNES some while back, but cannot locate my license. I would likely have used same email as with purchase of dBPoweramp. Anyway to locate my license for PerfectTUNES? It would save some money not having to repurchase the software, that is unless PerfectTUNES with DSF feature (when released) will cost extra for existing PerfectTUNE registered users.
You have tried your other older email addresses?
I recovered my PerfectTUNES order number, downloaded the registered version and installed. PerfectTUNES interface shows as "unregistered" with limitations that implies. Don't understand why not showing as registered version.
You would have to uninstall trial, by dragging it to the trash, then install the registered version.
