Multi-CPU issue with Beta2
  • adavison17
    • Jan 2007
    Hi there,
    I've been using Beta 1 successfully for a while now (long enough for the MP3 encoder license to expire ), and was really impressed by the use of dual core CPUs (i.e. encoding one track while ripping another).
    In Beta2 I have not seen this happening - it seems to only use CPU1.
    Any idea what may be causing this issue?
    Thanks for all the good work!
    Andy (Registered for years and loving it !)
    Re: Multi-CPU issue with Beta2
    Try Beta 3 and see if it still happens.
    • adavison17
      • Jan 2007
      Beta3 fixed the issue.
      Andy
      • danielg
        • Jan 2007
        I have the same problem like adavison17 besides that I used the alpha, and everything worked, until now.
        I tried beta 3 but it didn't help me
        It still uses only 1 CPU.
        Can anybody help, please?
          Did you install the dBpowerAMP Reference trial, or the PowerPack trial? dBpowerAMP Reference is required for multi-CPU support, among other things.
          • danielg
            • Jan 2007
            Thanks for the very quick reply.
            I installed the wrong version.
            Great support and product
            • danielg
              • Jan 2007
              I just downloaded and installed the latest Reference Trial from
              ... and again have no multi core support. It disappeared and now
              with the new version didn't reappear. Please help.
              Daniel
                Has your trial expired? Check dBpowerAMP Configuration (Start --> Programs --> dBpowerAMP Music Converter --> Configuration --> dBpowerAMP Configuration).
                • danielg
                  • Jan 2007
                  This is exactly what it says:
                  I try to convert some ape files into ogg-files and it does only one song, not two simultaneously
                  Daniel
                    You have the PowerPack, NOT the Reference version.
                      • 43898
                      Yes your reference trial must have been used up.
                      • danielg
                        • Jan 2007
                        I now got the picture. I then need to buy the Refererence version (with more features).
                        When will the Reference version be available? Thanks!
