CDGrab won't
  • ephoras
    • Feb 2007
    • 26
    CDGrab won't
    Registered and installed R12 last weekend on a newly created W2K Pro SP4 system and then tried to Rip some CD's to mp3 - it reckons all the CD's I put in are errored, but they play using Windows Media.
    I was going to buy the CD Writer as well but don't feel inclined if the Ripper does not work.
    Is it the setup or is there a problem with CDGrab?
    CD/DVD Details
    Manufacturer: LITE-ON
    CD Drive: COMBO SOHC-5232K
    Firmware: NK02
    Serial: Nov07 ,2003
    Maximum Speed: 9173 KB/sec (x52)
    Current Speed: 9173 KB/sec (x52)
    Spin-down After: 4 minutes
    Buffer Size: 2 MB
    Accurate Stream: Yes
    C2 Error Pointers: Yes
    Reads ISRC: Yes
    Reads UPC: Yes
    Re: CDGrab won't
    Are you running dMC as an administrator? When you say "errored" do you mean the conversion gives you errors, or the CDs are inaccurate/insecure?
    • ephoras
      • Feb 2007
      • 26
      Re: CDGrab won't
      I am in administrator mode
      The exact error for every track of every CD is
      Error ripping to mp3 (Lame) file name
      Unable to read CD, check CD disk frame LBA nnnnn
        Re: CDGrab won't
        What CD Communication set are you using, SCSI Pass-Through or Windows Limited?
          • 43916
          Re: CDGrab won't
          Try windows limited.
          • ephoras
            • Feb 2007
            • 26
            Re: CDGrab won't
            Thanks for the suggestions but they went around a mile over my head
              Re: CDGrab won't
              In CD Grab, click the Options button, scroll down until you see the CD ROM Section. You should see "Communication". Change the box beside it to say "Windows Limited" and see if that works.
              • ephoras
                • Feb 2007
                • 26
                Re: CDGrab won't
                Thanks for the explanation - it was set for SCSI Pass Thru (SPT)
                The options I've set it to is
                Windows Internal [For Limited Accounts]
                and it WORKS
                until the last track and then got the same error as before - thanks for the help
                tried several more cd's, but the same result - errors on the last track which is not recorded.
                The error in every case is
                Error ripping to mp3 (Lame), ..........track name.............
                Unable to read CD, check CD disc (frame LBA nnnnn etc.
                  Re: CDGrab won't
                  Try checking or unchecking the "Read into lead-in/lead-out" box in the Options
                  Also, what is the exact error when it is trying to rip the last track?
                  • ephoras
                    • Feb 2007
                    • 26
                    Re: CDGrab won't
                    I had previously tried checking that box, it is now unchecked and the error on the last track is
                    Error ripping to MP3 (lame), 'Track 15' to D:Music\Maddy Prior\2004 09 21 - Arthur the King\15 - Lark in the Morning.mp3
                    Unable to read CD, check the CD disc (frame LBA 231796 ripping 7 frames track end LBA 231803) [dRipperBurst::Rip]
                    Obviously the filename changes with each CD as do the LBA's and number of frames by 1 or 2.
                      • 43916
                      Re: CDGrab won't
                      This is a known issue on some drives on some discs, it is being investigated and will be fixed in R12.1 (keep an eye out for the beta so you can test)
                      • ephoras
                        • Feb 2007
                        • 26
                        Re: CDGrab won't
                        Just downloaded and installed R12.1 on top of R12. Tried to rip a CD again, but still can't rip the last track.
                        Information ripping to mp3 (Lame), 'Track 11' to 'D:\Music\Runrig\2007 - 2007 - Everything You See\11 - In Scandinavia.mp3'
                        ** Drive is unable to read into lead out, uncheck over-read option. [clRipperSecure::Rip]
                        Track 11: ERROR Ripping LBA 198616 to 220715 (4:54) in 0:41. Filename: D:\Music\Runrig\2007 - 2007 - Everything You See\11 - In Scandinavia.mp3
                        Unable to read CD, check CD disc (frame LBA 220690 ripping 24 frames track end LBA 220715)
                        Where is the over-read option to uncheck?
                          Re: CDGrab won't
                          Options --> CD ROM section --> second check box from the bottom.
                          • ephoras
                            • Feb 2007
                            • 26
                            Re: CDGrab won't
                            Thanks for the reply, if that is the "Read into Lead-in or Lead-out" box, it is not checked. I have tried checking the box with similar results.
                            I have tried the CD in an old Samsung SCR-3232 but it won't even read it in there at all, although I do hasten to add that this is a VERY old CD drive.
                            I have also tried loading the CD as a CloneCD Image, mounting it in a pseodo drive with the same "over-read" results.
                            The CD is brand new and hadn't ever been played, I have now played it OK.
                            I have tried 2 more CD's and they both failed on the last track.
                            Any other suggestions please?
                              • 43916
                              Re: CDGrab won't
                              You could remove the offset if it has been detected for the drive.
