HTTP(S)/WAN Remote access coming soon?
  • Al1967
    • Jun 2019
    Is there any possibility of adding remote access to Asset in a future update/release like Emby or Flex servers have?
    Since Google is retiring Google Play Music I've been using Emby (free version for now) when I have wifi away from home to give it a run before I purchase it. Playing downloaded music away from server requires purchasing the product. Which I will once GPM is gone & if illustrate doesn't have an alternative by then.
    Since most of the programs/apps on here manipulate audio, & do it well, I believe an Android app connecting to Asset would also work great!
    Al.
    G2J!
    • 43902
    Re: HTTP(S)/WAN Remote access coming soon?
    You just need a VPN connection to your home network, your router might have the option to set it up.
    • Al1967
      • Jun 2019
      Really? That sounds great. I can do that! Easy to set up.
      I read through a lot of the posts & most of the questions about remote access were answered with something like: since it is UPnP it doesn't support it.
      What Android app(s) work best &/or what ones would you recommend?
      I probably will purchased most of the programs on here early next month.
      Thank you for your response.
      Al.
      G2J!
        • 43902
        You would have to try the trials to see if they work for you (Asset).
        I am not aware of an android upnp player, but I am sure there are some.
